5spd swap questions
  • iXguido
    • Nov 2009
    • 730
    5spd swap questions
    I'm getting ready to do a manual swap on my ix and I'm wondering about the comparability of some parts. I'm planning to use a flywheel from a rwd and the matching clutch kit. Will this work?
    Also for the shifter linkage, are the parts interchangeable between the rwd and awd? I know I have the get the shifter carrier bracket as it is specific to the ix.
    If someone can clear up what works and what doesn't, that would be great.
    Thanks so much!
  • Mlarsen
    • 4082
    I know the clutch will work. If you're using a single mass flywheel be sure you are using a clutch kit for a single mass wheel.
    • iXguido
      • Nov 2009
      • 730
      Thank you very much. Anyone on the shift linkage?
        • 34844
        ix shift linkage is completely different
        • iXguido
          • Nov 2009
          • 730
          Thank you as well
