So i put some lowering spring on my ix and i was wondering if i really need the alignment done...it didnt seem to have been lowered that much
just got some h&r's
Tags: None
Only the front toe is adjustable stock. You can set that with a measuring tape.
Would be good to have your alignment checked, so you can be looking at camber/toe adjusters for the rear and/or camber plates for the front. -
don't need camber plates with H&Rs. I would get the toe adjusted and leave it at that, the drop is pretty mild. it basically puts you at stock RWD height. :pComment
