New tank
  • Hares1370
    • Oct 2013
    • 16
    New tank
    I've just pick up a new fuel tank. It has a hard line that runs into the tank while the old one doesn't. I'm just trying to see where all there lines need to go. I feel like one of these lines does have a place to connect. http://bavarianretro.com/img/p/3/6/8...ox_default.jpg
    This is a stock photo of the new tank
    buy 16111180175,Fuel Tank 16111180175,find manufacturers and suppliers of 16111180175,Fuel Tank 16111180175
  • The Dark Side of Will
    • Jun 2010
    • 2796
    • Hares1370
      • Oct 2013
      • 16
      Thanks
        • Jun 2010
        • 2796
        There are two styles of tank... the older 55(?) liter and the newer 63(?) liter. Are you trying to replace a 55 with a 63? That may explain why the new and old are different.
        The old tank has a transfer connection UNDER the driveshaft, which has to be disconnected to remove the driveshaft. The newer tank does not have that connection.
        I thought all the 325iX's that came to the US had the newer tank.
        • Andy.B
          • Sep 2011
          • 1650
          Not a big deal for the discussion at hand, but that is not accurate. You can remove the drive shaft with the fuel tank crossover pipe in place just fine.
            • Jun 2010
            • 2796
            Ok... I've never seen one so I wasn't going on first hand info.
