91 iX no start, but not throwing any codes
  • zcenterb
    • Feb 2014
    • 2105
    Hey r3v,
    So i just bought a 91 iX the other day and have been trying to trouble shoot that fact that it won't start. It will turn over great, but i seem to not be getting any spark. Also, i seem to have a pretty legit battery drain somewhere that i cannot find... as far as the parasitic drain goes, i have unplugged/removed everything i thought could be the culprit like Airbag system (was tampered with prior to my purchase anyway), stock alarm system, air-conditioning system, radio... the only thing i have yet to unplug is the OBC but I'm not sure if that will even help.
    The car is getting full power to all relays and all the relays work, all fuses are good, etc, main/fuel relay is grounding and working as it should, but the engine is not getting spark. I checked the power line coming into the Coil (the one with the +) and it is getting a steady 12v in, and seemed to have been getting power out of it as well, but it was inconsistent, obviously beaus it was charging and discharging as it should i think. I replaced the coil pack, distributor rotor and cap, and the line from the cap to the coil, all proven working, with no luck. PO replaced all spark lines and sparks and as far as i can tell they are all good.
    So, im stumped.... Anything that you guys know of the could be causing something like this? Bad DME/Harness? I also replaced the Crank pos sensor with a proven working one but nothing. Ill figure it out eventually I'm sure, but any help would be appreciated.
    Thanks in advance
    CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
    Instagram: @centerbarmotorsport
    Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
    The Fleet:
    -1984 325ei Lapis
    -1991 325ix Diamond
    - 2005 X5 4.4i Black Sapphire
    -1972 2002tii Fjord - SOLD 7/8/17
    -1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
    The Bike:
    -1980 R100RS Inca
  • fresh_TD
    • Aug 2013
    • 2457
    Check your ground cable from the block to car
    Sent from my Samsung Note 3
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • EyExR
      • Jan 2011
      • 959
      I would check main relay and DME. Then maybe fusible link...
      Also. I would pull the distributor cap and make sure everything looks good. I've had the center pin of my cap lose it's spring and this caused a no start...
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
      • spdracrm3
        • Sep 2009
        • 959
        how are you testing for spark and where ? need to check if anything is coming out of coil buy using a spark tester or holding the disconnected distributor cap end of the coil wire close to the valve cover or something metalic on the engine (be sure to hold the plug wire with insulated pliers or you could get shocked yourself) and have someone help crank it over while you look for spark jumping the gap of about 1/8- 1/4 inch. if no spark out the coil wire to ground test the ECU control of coil by using a test light on the coil - terminal and again have someone crank engine and see if test light lights up with key in run ,and then flashes with engine cranking . if test light doesnt flash the ECU is not sending signal to coil to fire , at that point you either have a wiring issue an ECU issue or ECU is not receiving RPM /cyl id signal it needs to operate.
        download you correct ETM here and study the engine electronics pages for where to test at ECU pins if further testing is needed
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • zcenterb
          • Feb 2014
          • 2105
          Ground from block to chassis is good, i tested sparks by your second method spdracrm3 (take out a spark and hold it close to clean metallic VC) and got no spark thus assuming i had no spark, and i replaced my distributer cap, distributer rotor, plug wire from cap to coil, and the coil itself with known working ones from one of my other cars and got nothing. Ill try your light test today and see if i get anything. The odd thing is though, its not thawing ANY codes... even when i disconnect an obviously code throwing plug like the HFM plug... is this a DME problem?
          The Fleet:
          -1984 325ei Lapis
          -1991 325ix Diamond
          The Bike:
          -1980 R100RS Inca
          • zcenterb
            • Feb 2014
            • 2105
            Just out of curiosity, what injected poundage/color do these cars run stock? Because i just noticed i had some odd yellow/tanish looking ones... and i know my other e30s all run the blue top 17s or whatever those are.
            The Fleet:
            -1984 325ei Lapis
            -1991 325ix Diamond
            The Bike:
            -1980 R100RS Inca
            • spdracrm3
              • Sep 2009
              • 959
              if you are using a sparkplug to test for spark you need to ground it fully against valve cover and look for spark in gap. if you use a plugwire alone you need to hold it slightly away from metal and watch for spark to jump gap. and test the coil spark output alone to see if it is working and its not a problem inside distributor
              these are very early and basic motronic ECU's and do not set codes as easily as today ECU's do , so dont be surprised if it take a long time for a code to show if at all
              Angus
              88 E30M3 X2
              89 325IX
              92 R100GS/PD
              • zcenterb
                • Feb 2014
                • 2105
                I know, i did both, no spark with either... picked up a brand new distributer and rotor and replaced them and still just turns over with no spark. Still need to test the output on the coil.
                The Fleet:
                -1984 325ei Lapis
                -1991 325ix Diamond
                The Bike:
                -1980 R100RS Inca
                • Liquidity
                  • May 2014
                  • 395
                  New cars don't throw codes for a no-start either. If the ECU doesn't know the engine is spinning, it assumes it's not, and it can't throw a code.
                  • zcenterb
                    • Feb 2014
                    • 2105
                    Already tried the Crank sensor, replaced it with one from a running car. Nothing.
                    The Fleet:
                    -1984 325ei Lapis
                    -1991 325ix Diamond
                    The Bike:
                    -1980 R100RS Inca
                    • spdracrm3
                      • Sep 2009
                      • 959
                      not true,l the newer ECU's have a starter engaged signal input and will set a codes for no crank/cam/maf/map sensor input knowing the starter is engaged after 10-15 sec.especially with the push start systems so it will turn off starter after long crank no start which is actually controlled by the ECU now too....
                      Angus
                      88 E30M3 X2
                      89 325IX
                      92 R100GS/PD
                      • zcenterb
                        • Feb 2014
                        • 2105
                        bump, checked my engine-chassis ground and thats good.
                        The Fleet:
                        -1984 325ei Lapis
                        -1991 325ix Diamond
                        The Bike:
                        -1980 R100RS Inca
                        • zcenterb
                          • Feb 2014
                          • 2105
                          confirmed no power on that top plug wire going from the coil to the distributor cap. So I'm not getting any power out of my coil to ignite my plugs. I am getting 12v on both of the wires going to the coil though.... and spark seems to be the only thing I'm missing... any thoughts?
                          The Fleet:
                          -1984 325ei Lapis
                          -1991 325ix Diamond
                          The Bike:
                          -1980 R100RS Inca
                          • johnt325ix
                            • Nov 2013
                            • 101
                            Timing? Check if distributer is in wrong position.
                            • johnt325ix
                              • Nov 2013
                              • 101
                              Also, are you sure your getting fuel? 2 fuel pumps in that car.
