Can't find the oil pressure sensor
  • Redeye X
    • Aug 2014
    • 2
    Help. Can't find the oil pressure sensor on my 91 ix. The one that goes to the cluster. Doesn't seem to be in the same place as the i.
    Thanks
  • spdracrm3
    • Sep 2009
    • 959
    right side of block ,below oil filter adapter and in front of engine mount , mounted vertically with connector on bottom for wire
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • TehRaydarlover
      • Mar 2013
      • 544
      I wanna say it on the passengers side just in front of the motor mount.
      Build Thread
      Rear Diff Rebuild
      Rebuildable Viscous Coupling
      Transfer Case Rebuild
      "Life is simpler with 12 valves"
        • 34844
        it's on the passenger side directly above the steering rack. in fact, you will almost certainly need to lower the subframe or jack up the motor to remove it.
        • Redeye X
          • Aug 2014
          • 2
          Got it. Well hidden little thing. Thanks.
