Rear transmission seal HELP!
    So I have my transfer case removed to install my z3 shift lever and replace the rear seal. Can anyone shed some light on what socket to use for the nut? I bought a GM oil sender socket but it is to small. Can anyone help!?
    30mm thin wall 12pt socket ,also make sure you have some anerobic sealer for re-install ,goes on splines (you will see old sealant on flange splines once removed)
    (such as
    Products
    Print
    Permatex® Anaerobic Flange Sealant
    - See more at: http://www.permatex.com/products-2/p....PPDZGLtY.dpuf )
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
      I used the 30mm axle socket but turned it down to reach in there. It has to be a thin wall socket or it will not fit.
      sigpic87 325E The Honey Badger
        Got it at Sears.
        Sent from my 831C using Tapatalk
        Rebuilding since 07/06/2016
        Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
        Poorboyz Feedback Thread
          Ok thanks everyone. I looked at my local sears and they didn't have a socket that big. I'll have to look around and find a 30mm deep and just grind it down. If I have any other questions about install and the sealant I will post back here. Thanks for the help!
            Ok managed to get the nut off and the puller thing.. I removed the seal and am ready to put in the new one. My question is where do I apply the flange sealer?
              clean old sealer off splines (both halves) ,install seal and then apply some evenly to very end of splines on trans output shaft and also down inside the leading edge of splines inside output flange. basically you trying to seal the spline area of the flange
              Angus
              88 E30M3 X2
              89 325IX
              92 R100GS/PD
                and clean the grime off the seating surface of the seal before you install it.
                  Ok thanks guys for all the help I really appreciate it. Its going back together now.
                    Ok I'm putting everything together. And i was wondering if there are torque specs for all the guibos? Will it cause vibration if not torqued down properly?
                      um i take it you didnt see this two posts down from yours?
                      would only add direct from factory manual on Guibo replacement
                      important
                      "only tighten nuts or bolts on flange end whenever possible by design to avoid strain on joint disk"
                      Angus
                      88 E30M3 X2
                      89 325IX
                      92 R100GS/PD
