FRONT Guibo bolt torque
  • The Dark Side of Will
    • Jun 2010
    • 2796
    I don't have my Bentley handy, and I'm not sure it would cover this anyway...
    To what torque to I tighten the front driveshaft guibo bolts?
    Thanks!
    • 34844
    I think its around 50ft/lbs but since they are locknuts i just make them tight enough. Never had an issue.
    • spdracrm3
      • Sep 2009
      • 959
      torque specs
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
        • Jun 2010
        • 2796
        Originally posted by spdracrm3
        https://www.bmwtechinfo.com/repair/main/941en/images/941759.jpg
        Thanks, but it's not in this table.
        I used 25 ftlbs because they are 10mm bolts, but I would like to find the real number.
        • spdracrm3
          • Sep 2009
          • 959
          this one covers all coupling/guibo bolt size/grades
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
            • Jun 2010
            • 2796
            Looks like 48 NM for the 8.8 bolts and 64 for 10.9's... ok. I didn't notice which was which.
            The "drive" bolts from the shaft to the guibo are through bolts with loose nuts.
            The "driven" bolts go through the guibo from the same side as the "drive" bolts and thread into the fingers on the input flange of the front diff. I didn't notice if they were different classes.
            Thanks!
