I think i broke my car
    Put the car in gear with the engine off, rolls down hill while making a whirring noise from the rear end. Makes same noise when accelerating in forward or reverse, I don't believe it is the clutch. Sounds like the output flange on the differential is stripped. Anyone else have any ideas?
    Does it accelerate forward or reverse under it's own power, or just keep rolling?
    -FW
      Also, it's a fulltime AWD car, a stripped rear diff should not allow the car to just roll around like it's not connected to anything unless the AWD is a little cooked.
        it rolls slowly, and it doesn't do it under deceleration (I guess the engine doesn't have enough braking force)
          so I didn't strip the front shaft, I broke the differential, I think, ill post a video and hopefully someone tells me something just popped out of place, but ill start searching for a new diff in the meantime
            Lol I fixed it, anyone wanna guess what happened?
              Drive shaft popped out?
              E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
              E30 M50 6 spd 764whp @ 24psi.
              E30 M20 6 spd 675whp.
                Yup passenger side
