well like i the stated the IX has a one piece rear driveshaft that has a guibo at the front and one U-joint at rear . when installing and putting in a NEW guibo you need to align the arrows as seen in the picture ,torquing to spec.if you just remove and reinstall driveshaft leaving the guibo attached to the transmission yoke ,when you go to re-install it as there are three bolts that makes three possible ways to install and it doesnt matter which if you didnt mark it when taking apart.
and all three guibo's are subject to premature wearout if not installed correctly (by aligning the arrows)
