E34 IX Front Driveshaft
  • AndrewBird
    The Mad Scientist
    • 11898
    Cleaned and greased the splines on my front driveshaft the other day and took some pictures. Thought you guys might like to see.
    Splines
    Dust Seal
    The E30 IX doesn't have the metal cup and dust seal like this, does it? Seems like a much better design and would keep grease from "washing" out.
    • 34839
    The E30 has a dust shield, it's plastic but it works fine. The rubber o-ring is built into the transfercase.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      The E30's plastic dust shield engages o-rings on the T-case sprocket snout and the driveshaft. It's well sealed.
      • Nisse Järnet
        • Aug 2013
        • 1221
        You probably know this but you can remove the steel cup to get better access when cleaning etc :)
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
          • Jun 2010
          • 2796
          Thanks for sharing pics!
          • AndrewBird
            The Mad Scientist
            • 11898
            I didn't but mine was still nice and shiny zinc oxide plated on the inside. A small brush and some super clean got it back to like new condition.
