Clutch kit for turbo ix?
  • madman23
    • Jan 2007
    • 498
    What clutch, pressure plate, and flywheel is everyone using? I will be making 350hp and around 300ftlbs to the wheels. I have found very few companies that say ix specific. I know stock for stock the pressure plate part number is different but I really cant figure out what the difference is. Clutch pn is the same though. Any info will help. Thanks.
    • 34827
    there's really nothing ix specific about the ix clutch. it's a standard M20 single mass flywheel. Originally, we had a stiffer pressure plate than the RWD guys, but they merged those part #s ages ago. they are completely interchangeable.
    • Nisse Järnet
      • Aug 2013
      • 1221
      Sachs 618 plate.
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
        • 34827
        ^ agreed. Lots of capacity, drives like stock.
        • madman23
          • Jan 2007
          • 498
          Awsome. Thanks for the info guys.
          • CrazyPrime
            • Jun 2014
            • 286
            Does the 618 come with a clutch? And where is the best place to buy from?
              • 34827
              The 618 is just the pressure plate.
              • CrazyPrime
                • Jun 2014
                • 286
                So I assume you just run the stock clutch disc? Is that good for around 350-400hp?
                  • 34827
                  I would run the sport disc.
                  Fyi, clutches are rated by torque, not hp. I believe the sachs 618pp holds 250nm with a stock disc (it might have been 300nm but i can't remember exactly). A sport disc should be more.
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    Sachs says 450nm with stock disc I believe, and that's on the low side :)
                    • CrazyPrime
                      • Jun 2014
                      • 286
                      where did you guys buy your 618? And is the "sport" and "hd" any different? I was thinking about running a centerforce clutch disc with the Sachs 618.
                      • madman23
                        • Jan 2007
                        • 498
                        Is there a part number for the sport or HD? I just can't see how a stock clutch can hold that much torque. Can anyone recommend a flywheel that isn't aluminum?
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          There's only one sachs 618. Use stock M20 flywheel.
                          I get most of my parts from PPF but they're in Sweden :P
                          • madman23
                            • Jan 2007
                            • 498
                            So I went with a Sachs 618 Pressure plate and a clutcmasters fx350 disc. I will update this thread once its in the car. Thanks for all the advice.
                            • CrazyPrime
                              • Jun 2014
                              • 286
                              Let me know what happens madman, and where did you get just the disc from clutchmasters? How much did the plate and clutch run you?
