im trying to get the one on my car loose. bent a screw driver in the u joint tryin to turn it either way, so im thinking i wasnt on the nut. anyone have a breakdown of that assembly? Real oem doesnt have a diagram that i could find. any help appreciated.
Drive shaft coupling nut
when you say coupling, are you talking about the guibo?sigpic
Gigitty Gigitty!!!!
Nope, the one in the back, I'm very familiar with guibos if your putting the 8 bolt one in a 2002, make sure the band stays on until it's installed :P but I do wonder. If the u joint or coupling is loose and the d shaft is vibrating back there, do you think I would be able to feel it in the shifter?
Originally posted by 2002tiiguy View PostNope, the one in the back, I'm very familiar with guibos if your putting the 8 bolt one in a 2002, make sure the band stays on until it's installed :P but I do wonder. If the u joint or coupling is loose and the d shaft is vibrating back there, do you think I would be able to feel it in the shifter?
It's possible that you'd feel vibration in your shifter, but my guess is that if your ujoint is loose/bad, you'd feel it in the whole car, not just the shifter. The easiest way to check is if you just climb under your car (all 4 wheels on the ground and e-brake on) and try to shake the driveshaft. If you can make it move in any direction other than the twisting motion, somethings wrong.
What drive shaft coupling nut were you trying to loosen, this one: http://s614.photobucket.com/user/dan...haft.jpg.html?
