Rial Milano wheels 16x6.5 + 40 mm offset
  • 95BMWIC
    • Apr 2012
    • 353
    Ok
    Im researching this wheel and I believe I can make these work on an IX with only a set of hubcentric rings.
    I wanted to post it just to make sure.
    Rial Milano wheels 16x6.5 +40mm offset - came off a mini cooper supposedly.
    will these work?
  • 95BMWIC
    • Apr 2012
    • 353
    So - discovering this thread - I may have made a mistake - 56.1 Mini cooper vs 57.1 BMW.. http://www.r3vlimited.com/board/showthread.php?t=233160
    not quite sure this will work without machining..
    • 95BMWIC
      • Apr 2012
      • 353
      Owner states that he has a hub centric ring in it - for a mini and that they were an aftermarket purchase - states hub ring is 63.3 to 56.1 ..
      So I am assuming the ET of 40 is safe..? and that I can order a centering ring of 63.3 to 57.1?
      to work on an IX..?
      • 6A LDY
        • Jul 2014
        • 318
        yeah, et40 is plenty high enough (stock is 41), and you should be able to find the hubcentric rings no problem, I went with aluminum rings for mine but plastic is ok too. If you run 5mm spacers it will put the rim in almost the exact position as stock
        1988 325iX - sold but not forgotten
        1984 MTech1 323i
          • 34839
          doesn't seem worth it to me for a 6.5" wide wheel, unless you're going to run 195s.
          • 6A LDY
            • Jul 2014
            • 318
            It would be great for a winter wheel though
            1984 MTech1 323i
