T-Case mount replacement?
  • Chrisbike
    • Mar 2015
    • 688
    Is it possible to remove the transfer case rubber mount with the T-Case still in the car? I'm curious if anyone has done this. Mine looks OK (has some cracks) but I want to replace it now while taking care of other various things. Part # 23711130502
    Build Thread
    https://www.r3vlimited.com/board/sho...d.php?t=419655
    Parts Thread
    https://www.r3vlimited.com/board/sho...d.php?t=408302
  • Seawolf
    • Feb 2015
    • 270
    Yes, I've done it, it is doable and it is a complete cow.
    Cut the rubber, collapse the metal sleeve and knock it out towards the rear of the car (reasonably awkward). You can't get a sawzall into this mounting to cut the metal shell but you can get a HF mini sawzall in there, the HF blades are shit so use a good jigsaw blade being careful not to damage the ally TC mounting.
    The bolt hole in the mount is offset which adds a greater level of awkwardness.
    You'll need a very shallow receiver and cap big enough to fit the rear of the TC mounting hole (including the offset) while not slipping off the casting, and a press cap big enough to fit the outer shell of the new mounting (again including the offset).
    Put the new mounting in the freezer, everything helps with this job.
    About 3 hours if I remember correctly - though I'm trying not to remember that job at all.
    Good luck.
    • Chrisbike
      • Mar 2015
      • 688
      I'll have to put it on the backburner since I have more important things to do.. I'll have to pull the t-case some time this year for a rebuild so I'm just going to wait. Glad to hear it's doable as its a b*tch to drop the t-case.
      Build Thread
      Parts Thread
        • 34844
        I just bring the t-case to a shop and have them press it out and press the new one in. Doesn't usually cost very much. Getting the new bushing in there while under the car sounds like a nightmare.
        • Seawolf
          • Feb 2015
          • 270
          It's like eating a double Anchovy pizza with extra Anchovy's just so you can say you've done it....
