Which Springs for IX
  • GK-E30M3
    • Apr 2008
    • 816
    Ok Guys what's the best place and good on price to get the Konis & H&R Springs I am going with that set up time to get the IX back on the road
    • Chrisbike
      • Mar 2015
      • 688
      Turnermotorsport is 20% off on Komi products.
      Build Thread
      https://www.r3vlimited.com/board/sho...d.php?t=419655
      Parts Thread
      https://www.r3vlimited.com/board/sho...d.php?t=408302
      • GK-E30M3
        • Apr 2008
        • 816
        Thanks Guys I pulled the trigger and got them from TMS
        • Chrisbike
          • Mar 2015
          • 688
          Glad to hear! Let us know how they feel!
          Build Thread
          Parts Thread
          • berlow94
            • Jan 2013
            • 1063
            Why does nobody use linear rate big boy springs?
            I can't stand driving on progressive springs...
            The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
            • Chrisbike
              • Mar 2015
              • 688
              You make a point, does anyone make them for e30s let alone iXs though?
              Build Thread
              Parts Thread
              • berlow94
                • Jan 2013
                • 1063
                Sure. Hypercoil, eibach. You just need coilovers adjusters to mount them. ;)
                • berlow94
                  • Jan 2013
                  • 1063
                  I guess people are more interested in bolt on parts. They don't like modifying things themselves.
                  Once you have "normal" spring perches, you can buy and spring size, length, and rate that you want for about $50 a piece. Way easier to change than stock springs too.
                  Past couple days I've been looking at exhausts for instance. Atleast $500 for a cat back exhaust?
                  I had my local exhaust shop build me an entire system from the manifolds back including a borla muffler for $300... y-pipe where I wanted it, single 2.5" pipe all the way back, bends where I wanted them, a flange where I wanted it, hangers where I wanted them. Etc.
                  • Chrisbike
                    • Mar 2015
                    • 688
                    Generally that's true. Custom work is really about connections or shop access etc bolt ons take care of that.. As for the exhaust I did that exactly and the cat back didn't even fit/ needed the brackets modified anyway. As for coilovers, I'm not sure if it's the best investment of your driving your iX everyday. I'll probably look into it in the future. I'd rather not pay almost two grand for gc coilovers anyway. I need to do a clutch, rebuild the transfer case, rear subframe bushings etc before I can think about that. Probably do some head/ exhaust work aswell. Aren't the coils in the GC Kit eibach? Most iX owners are on the same page. Maintaining these are already expensive enough..
                    Build Thread
                    Parts Thread
                    • berlow94
                      • Jan 2013
                      • 1063
                      I agree. This is an upgrade to be done after mantinence items have already been taken care of.
                      $2k?! A coilover kit from GC with springs is only like $600.
                      • iXguido
                        • Nov 2009
                        • 729
                        2k is about right for the full setup. F&R koni shocks/struts (~$700), camber plates ($400), heavy duty RSM's ($100+), coils ($429), modifying the strut housings (Ithink GC will do this for $250 shipped on your dime?). You'll also need shorter sway bar links or need to modify the stock ones. You can piece it together yourself and do all the work yourself like I did to save a bit of money
                        • berlow94
                          • Jan 2013
                          • 1063
                          Yes, but take it that you have good functioning shocks, buying the spring & adjuster kit is only $429. If you don't have a welder you can have any shop cut the stock perches off and weld on the collars for the adjusters for $50. That's $500 all in!
                          Camber plates, RSM's, shorter sway bar links, etc. is all extra upgrades that are not needed to convert to linear rate springs with coilover adjustment (for height adjustment and more importantly corner balancing the car).
                          • Bolestuff
                            • May 2012
                            • 51
                            It appears the po of my ix put convertible HR springs in with billy hd struts. The front blew after about 10k. I removed the bump stops right after I got as it was hitting them often. Should I change out the spring for ix specific?
                            • berlow94
                              • Jan 2013
                              • 1063
                              Not sure what the stroke is on the vert front suspension but i'd imagine that it's shorter than the IX front. I will have good condition stock IX springs available soon if you're interested.
                              • iXguido
                                • Nov 2009
                                • 729
                                I suppose as long as a person is using spring rates close to stock and keeping the height adjustment to a minimum; that would be fine.
