iX Random Thoughts/ Questions
  • Chrisbike
    • Mar 2015
    • 688
    Why the heck does the iX have two clutch switches?
    Build Thread
    https://www.r3vlimited.com/board/sho...d.php?t=419655
    Parts Thread
    https://www.r3vlimited.com/board/sho...d.php?t=408302
  • TimeMachinE30
    • Jun 2014
    • 3749
    Can we just ask questions or does an answer actually need provided?
    ACS S3 Build / Dinan 5 E34
    • Nisse Järnet
      • Aug 2013
      • 1221
      I think one is for the ECU and one for cruise control? I only have one, but i dont have cruise control..
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
      • Eskie
        • Dec 2014
        • 162
        Mine has a switch but it will still start without the clutch pressed in
        • Chrisbike
          • Mar 2015
          • 688
          Just ask questions if you have one; I didn't want to make a useless thread but was curious if anyone knew this.
          That might make sense. Maybe it's some sort of signal sent to the ecu and it effects the "traction abs system"
          No e30 has the clutch start interlock keeping you from starting it until you depress the clutch; it wasn't introduced until the e36.
          Build Thread
          Parts Thread
          • Chrisbike
            • Mar 2015
            • 688
            upgrading the rear sway bar to 16mm? I found a eibach rear bar on another e30 at the yard. And I figured it wouldn't hurt it. But I also don't want the car to feel too neutral.
            Build Thread
            Parts Thread
              • 34844
              One is for the abs, the other is for cruise control.
              Easily deciphered by looking at the ETM. ;)
              • Chrisbike
                • Mar 2015
                • 688
                Yeah the one on the bottom is cruise control, top is abs
                Build Thread
                Parts Thread
                • berlow94
                  • Jan 2013
                  • 1063
                  What does depressing the clutch while the ABS is active do?
                  The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
                    • 34844
                    it's for engine braking control.
                    if you lift the throttle without putting in the clutch on an icy surface and the wheels slip, the mercury switch on the driver's side will stay open (open = you're not slowing down) and it will open the ICV (by sending an on/off signal to the DME on C101 pin 19), which should reduce engine braking and stop you from slipping.
                    Basically, it's a really crude, early version of ASC/DSC.
                    • ACVC325ix
                      • Dec 2016
                      • 123
                      No e30 has the clutch start interlock keeping you from starting it until you depress the clutch; it wasn't introduced until the e36.[/QUOTE]
                      I am 100% sure that I can start my '91 IX without depressing the clutch...
                      • Questions
                        • Jan 2017
                        • 4
                        Sending unit
                        Will an e36 fuel gage sending unit fit my e30 325i??
                          • 34844
                          no.
                          • aaron325ix
                            • Jun 2007
                            • 1489
                            Wow, learn something new everyday. So in dry conditions, driving along in 4th gear I let off the throttle and the car slows down.
                            If icy conditions, I let off the throttle and something different happens?
                            I never noticed it in all my time in the mountains, but then again I've never had trouble in the iX in snow/ice. ;)
                            • Nisse Järnet
                              • Aug 2013
                              • 1221
                              It detects if the wheels locks up during engine braking, and if they do the ECU raise the engine rpm to let the wheels get rolling again :)
                              Its like a ABS system for engine braking!
