Finland-Fix for the e34 ix?
  • jute91
    • Nov 2011
    • 581
    Wondering should I start making these "Finland-Fix" extended spline heads for the e34 525ix too? Need to buy transfer case for measuring though...
    But Would there be interest? comment your thoughts.. I'm about to buy e34 ix soon
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
  • Nisse Järnet
    • Aug 2013
    • 1221
    I might be interested, havent had any problems with stock splines yet though. Im using a ~1cm spacer.
    I could measure if you want, actually i think the splines is the same as the splines in a 325i prop shaft for example.
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      Is a US based English-language forum the best place to ask this question? ;-)
      • jute91
        • Nov 2011
        • 581
        Well 90% of my e30 shafts have been sent to US... ;)
          • Jun 2010
          • 2796
          Almost zero % of AWD E34's went to the US...
          • jute91
            • Nov 2011
            • 581
            Thanks... so no need to make an uppgrade for it then :D
              • 34839
              Pretty sure 525ix splines are bigger/different from e30 325ix.
              If you're looking for ideas, a CV joint replacement would probably be worth looming into - new IX parts are basically unobtanium, and there's probably decent demand.
              Or maybe a 13:1 steering rack kit.. That isn't vaporwear. ;)
              • psmura
                • Mar 2012
                • 119
                ^ CV Joint replacements pleaseeee!!
                1989 325ix
                1992 325ic 770A
                2002 M3
