Front driveshaft install question
  • E30andy
    • Aug 2016
    • 504
    Hey Guys,
    Me again....
    Trying to get my front driveshaft back in. Having trouble with the 3 bolts that bolt into the output flange of the front diff. The bolts without the locking nuts.
    They won't tighten for some reason. They get started, tighten up a little, then loosen right up again, liked they are stripped or something. What am I doing wrong?
    Thanks!
    Andy
    89 325ix coupe Diamondschwartz
    1994 Mazda Miata
    • 34839
    Unfortunately it sounds like they are stripped. What do the threads look like?
    • E30andy
      • Aug 2016
      • 504
      I have to take it apart to check. The bolts look fine and they were tight when I took them out (if I remember correctly, it's been awhile).
      If the threads are stipped can they be tapped and rethreaded?
      1994 Mazda Miata
      • E30andy
        • Aug 2016
        • 504
        Wouldn't it be odd for all 3 of the holes to be stripped? Could the driveshaft be too deep in the transfer case and the bolts just aren't catching enough of the threads on the output flange?
        1994 Mazda Miata
        • E30andy
          • Aug 2016
          • 504
          Looks like user error guys! Installed the centering pin wrong, duh!
          Another question....
          So, after looking at realoem, I dont seem to have the "ring cover", #15 in the diagram
          https://www.realoem.com/bmw/enUS/sho...diagId=26_0040
          How important is that part?
          1994 Mazda Miata
            • 34839
            it's just a bushing, I don't think it's super critical.
            • E30andy
              • Aug 2016
              • 504
              Thanks Nando! You are a big help, appreciate the quick response!
              1994 Mazda Miata
              • Nisse Järnet
                • Aug 2013
                • 1221
                That bushing makes the drive shaft sit in center so i would highly recommend using one! You could get vibrations.
                E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                E30 M50 6 spd 764whp @ 24psi.
                E30 M20 6 spd 675whp.
                  • 34839
                  I thought that was part of the front input flange - I thought there was sort of rubber "washer" that is pictured in the ETK.
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    I could be wrong, but it really looks like the centering piece :)
                    • E30andy
                      • Aug 2016
                      • 504
                      It was actually still there. Its just a flimsy piece of rubber, appears to be a bushing, doesnt look very important.
                      1994 Mazda Miata
                        • 34839
                        yeah, I'm pretty sure there's a washer/bushing thing, and then there's the actual centering piece in the diff flange. I think that part is replaceable too, but they aren't the same thing. you could probably put any kind of rubber washer/o-ring in it's place and it would work just fine.
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          So what does the rubber washer even do? :)
                            • 34839
                            Prevents metal on metal? I dont think its extremely important - you cant compress the shaft into the flange any further than the flex disc allows anyway.
