Reattach steering joint?
  • driftxsequence
    • Apr 2015
    • 203
    Maybe I need to stop hitting it with my purse, but I dropped the subframe and when reattaching I did not line up the steering joints. I've loosened the bolts on the joints and it won't move...how do I get it to un-clamp?
    325IX Build Thread
    RX7 Build Thread
  • E30-325iS
    • Sep 2011
    • 191
    Try completely removing the bolts, not just loosening them.
    • vpilarrt
      • Jun 2006
      • 2096
      Yes, you have to do this but you may also need to spread the clamp a little by driving a screwdriver or small chisel into the slot.
        • 34839
        yep, the joint won't come out unless you remove the bolts entirely. it's a safety design.
        • driftxsequence
          • Apr 2015
          • 203
          Where should I be disconnecting?
          325IX Build Thread
          RX7 Build Thread
            • 34839
            Just pull out the bolts all the way. Then you will be able to slide the U-joint off the shaft.
            • driftxsequence
              • Apr 2015
              • 203
              So the way I did it was remove the splined joint as noted above. and I knocked out the 2 studs from the joint. i put the joint back in, slid the guibo in place and then pushed the studs back in and bolted it down.
              Hope this can help someone in the future!
              325IX Build Thread
              RX7 Build Thread
