Rear swaybar upgrade
  • D.Martijn
    • Sep 2016
    • 1024
    I'm thinking of changing my stock swaybar for an aftermarket one, I would like to have little bit less understeer when it's wet.
    What swaybars are you guys using and how are you liking it?
    Thanks.
    1990 325iX Touring - November 2018 R3V Car Of The Month
    1980 Volkswagen Golf mk1 1.1
    1974 BMW 2002 Touring
    Instagram
  • The Dark Side of Will
    • Jun 2010
    • 2796
    I guess there isn't a softer front bar available.
    • Kershaw
      • 11822
      I think the only option you have is adding adjustable end links.
      AWD > RWD
      • D.Martijn
        • Sep 2016
        • 1024
        Correct me if I'm wrong but when you thicken the rear swaybar, you increase the chance to oversteer right and thus making it push less?
        Instagram
        • Kershaw
          • 11822
          Somehow I read front sway bar. The rear sway bar is the same between all e30s. Put a stock i/e/es/is sway bar in there if you like. Or disconnect the front sway bar.
          Or run skinnier tires all the around and use the gas pedal more. Lol.
          What's your purpose, just trying to have fun? The ix slides sideways very well, you just have to be on the appropriate surface.
          AWD > RWD
          • D.Martijn
            • Sep 2016
            • 1024
            I just want to get some of the understeer removed :)
            Not looking to drift a corner lol
            Instagram
            • flyboyx
              • 8371
              the ix and m3 came with 14mm rear bar. the rest all came with 13mm
              Gigitty Gigitty!!!!
              • Kershaw
                • 11822
                Right, I meant they're all the same between i/e/es/is. That was pretty poorly worded.
                AWD > RWD
