Well I guess there could still be an issue with the shutoff valve being powered when it shouldn't be so worth disconnecting electrical connector as an easy diagnosis.
Actually getting to the blend door requires box removal and disassembly ,but the control cable attaches to a lever on the right side of the box right behind the floor vent so you could remove that piece and make sure lever moves thru full motion ,but you cant see the door is actually moving inside unless the core is out and then you can see it's movement thru the slot on left side where core was as you move the temp control dial. With it out you could also check airflow thru AC evaporator to make sure it's not plugged with debris or something fallen in front of it.
I have a complete hvac box out and could try to take pics ,that diagram you posted gives and good idea how things should be just not what things are on an actual case
Sent from my SM-G360V using Tapatalk
