Viscous coupling welded to planetary gear
  • D.Martijn
    • Sep 2016
    • 1023
    Hey guys,
    I got a question, so my uncle also has a 325ix touring and his viscous coupling is shot. He did get an other one some time ago but we didn't have time then to fit it.
    Today we had a look to test it out of the car like flyboyx stated here on the forum. Turned out we could not feel any fluid resistance, in fact we could not get the thing to spin! It's like someone welded it tight like you would do with a diff.
    He called the guy where he bought it from but turns out he doesn't know much about the iX and he bought a lot of parts which included this T-case.
    Being that I was eager to find out what was wrong I started with disassembling the damn thing. Only to discover that the viscous coupling was welded to the planetary ring gear. Has someone ever seen this before? Why would one weld the VC to the gear? Because of the welding the planetary ring gear is also warped.
    My second questions is, could we try and save the VC as it's not discolored. Obviously it had some heat put into it because of the welding. I'm thinking to grind the welds off (some of them are cracked) and testing the VC again out of the car. Would only be a small job anyway. We could use his old/original T-case and use all the good parts and make 1 good out of 2 bad ones.
    Some input on this?
    Would appreciate it, thanks!
    1990 325iX Touring - November 2018 R3V Car Of The Month
    1980 Volkswagen Golf mk1 1.1
    1974 BMW 2002 Touring
    Instagram
  • spdracrm3
    • Sep 2009
    • 959
    Originally posted by D.Martijn
    Hey guys,
    Some input on this?
    Test the VC first before going to all that effort, only reason I can think they did this is its already bad.
    Sent from my SM-G360V using Tapatalk
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • Kershaw
      • 11822
      Were they trying to create a welded diff for the transfercase? Would that even work? Wouldn't that break things unless the car was going in a straight line?
      AWD > RWD
      • spdracrm3
        • Sep 2009
        • 959
        Would definately increase stress/wear on drivetrain
        Need to dig out my spare tcase and figured out what they are doing here
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • spdracrm3
          • Sep 2009
          • 959
          yup thats what they have done is locked it up taking the VC and planetary gear set out of contention ,that's going to be hard on driveshafts and chain . pretty much assume that VC is bad. and TC wont last long
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
          • D.Martijn
            • Sep 2016
            • 1023
            Yes, I was thinking the same. Although the guy he bought it from does a lot of auto cross/dirt racing so maybe that's why? I'm not sure.
            Of course I would first test it on the bench with it's old housing and parts.
            That's also what I was thinking.
            Ok, thanks for the input!
            Instagram
            • D.Martijn
              • Sep 2016
              • 1023
              Took the oppertunity yesterday so cut the welds and removed the coupling
              The big snap ring is welded to the planetary gear ring so I couldn't remove it
              There is some black residue/substance on the back side of the coupling though
              Decided to clean the welds some more, I'll now reassemble to whole TC and do a bench test to determine the condition of the VC.
              Instagram
              • The Dark Side of Will
                • Jun 2010
                • 2796
                Does the VC work?
                • D.Martijn
                  • Sep 2016
                  • 1023
                  Originally posted by The Dark Side of Will
                  Does the VC work?
                  Haven't tested it yet, will do this weekend
                  Instagram
                  • flyboyx
                    • 8371
                    judging by your photo, that black residue is silicone fluid from the inside of the coupling. my guess is that it is bad. even if it seems to test good, i wouldn't use it if i were you.
                    good god! i just can't imagine how someone thought this was an acceptable repair?
                    now that you have the 2 pieces cut apart, you can probably hold the viscus coupling in a vise, put the planetary shaft back in and try to turn the inside of your coupling that way. you can use your hands or a strap wrench to spin the planetary shaft. if you don't have a vice that big, have a friend hold the vc while you hold the planetary. simply try to spin them against each other by hand.
                    if the coupling is by some miracle holding fluid, it should be very difficult or impossible to turn the inside of the coupling this way.
                    Gigitty Gigitty!!!!
                    • flyboyx
                      • 8371
                      a long time ago, myself and others have posted threads about rebuilding viscous couplings. i can't remember if it was here or e30tech. perhaps one of you reading this can do a search for it? i'm pretty sure my photos will be long gone.
                      assuming it is bad, you can cut one of the weld lines on a lathe to open it up. i would cut the one on the thick heavy side you have facing up in your photo above. check the plates inside for warpage. if you have another vc, you might cut that one open to see if you can make a complete set of un warped plates out of two.
                      the seals are available from mcmastercar. the fluid is supposed to be a mixture of 60,000 and 100,000 to give you around 80,000. i can't remember the units though i think its something like "cst".
                      i would just buy 100,000 fluid. seems like you can buy it by the quart or liter. refill the coupling to about 70% and carefully weld it back together. you will need to find a way to weld it without overheating your new seals. the upper end of the temp range for the rubber is iirc around 200 degrees F.
                      Gigitty Gigitty!!!!
                      • spdracrm3
                        • Sep 2009
                        • 959
                        Posts are still available for viewing in E30tech IX section .
                        Angus
                        88 E30M3 X2
                        89 325IX
                        92 R100GS/PD
                        • spdracrm3
                          • Sep 2009
                          • 959
                          Posts are still available for viewing in E30tech IX section . Also plates can be straightened in a press as long as costing isnt worn completely off
                          Angus
                          88 E30M3 X2
                          89 325IX
                          92 R100GS/PD
                            • Jun 2010
                            • 2796
                            Hell, there's at least one VC rebuild thread right here on R3V: https://www.r3vlimited.com/board/sho...d.php?t=406859
                            ETA:
                            Yeah, that was my take on that photo as well. Looks like something coming out of the seal and tracking toward the perimeter of the VC due to centrifugal force.
                            • D.Martijn
                              • Sep 2016
                              • 1023
                              I was thinking the same, I would prefer to get an other T case but not sure what my uncle will decide. Still don't know why one would do this lol.
                              Thanks for the input, I'll try it first your way, if it checks out good I'll do a bench test with it fully assembled in the TC
                              I've seen the threads on r3v about the rebuild, I've been thinking about doing that/trying at least with one of the VCs..
                              ETA:
                              I know, although the oring isn't completely blown apart like pictures I've seen online.. We'll see
                              Instagram
