Help With Camber
  • flyboyx
    • 8371
    Have you thought about taking your car to the body shop? Maybe it might be a good idea to put it on the frame rack and have it pulled back to spec? Is this even a thing?
    Rather than slotting the tower, maybe it would be better to move the holes in the strut mount?
    Gigitty Gigitty!!!!
    • Chrisbike
      • Mar 2015
      • 688
      +1 you have a nice iX. try to get it fixed proper...
      Build Thread
      https://www.r3vlimited.com/board/sho...d.php?t=419655
      Parts Thread
      https://www.r3vlimited.com/board/sho...d.php?t=408302
        • 34830
        ^Nah. Its probably just a bent strut.
        • EyExR
          • Jan 2011
          • 956
          I was thinking that might be it as well. I have a spare strut housing. I'm going to swap it in and see how it goes.
          My 325iX DIY Threads:
          Front Wheel Bearing Replacement
          325iX Rear Subframe Bushings and MUCH more w/pics!
          325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
          • EyExR
            • Jan 2011
            • 956
            What if I just put a couple of washers between the strut mount and tower? That should cause camber to change, no?
            Maybe like this?
              • 34830
              Uh, no. All that will do is slightly raise your car.
              • EyExR
                • Jan 2011
                • 956
                Ah crap. Lol.
                It’s not a bent strut, unfortunately. I guess my only option now is to try to move the studs on the strut mount. The problem is there’s very little room on the mount to do that. I may need to notch the towers a bit.
                Is there a way to figure out how many millimeters of movement the strut mount needs to move toward or away from the engine bay to get a 1 degree change in camber?
                • EyExR
                  • Jan 2011
                  • 956
                  I moved the studs over as far as I could. Now I'm not sure if I did too much or too little but this is what I got. If anyone knows the exact amount to move them over to achieve 1 degree in change in camber that would be great. I used this strut mount as a test dummy. I have a new strut mount I can use once I can be more exact.
                    • 34830
                    I'll see if I can dig mine up. I can't recall if both or only one of my mounts was the offset version.
                    • flyboyx
                      • 8371
                      I bet a body shop could check the body alignment for less than 200 bucks. I think I would start there.
                      Gigitty Gigitty!!!!
