I compiled all of the 325iX suspension info I could find in various threads into one single spreadsheet. Figured this would be a better way to keep track of everyone's setups. Feel free to add your setup and offer up some feedback.
325iX Suspension Database
Tags: None
Where are you measuring the "front height" from? ground to top of wheel well? -
According to this thread, where I pulled the ride height data, ride height is measured from the "center of the wheel/hub to the bottom edge of the fender lips": https://www.r3vlimited.com/board/sho...d.php?t=360750
Wheel center point to fender lip is probably the easiest and most consistent way of measuring ride height regardless of tire diameter!Comment
it should always be from the fender lip to the center of the wheel - otherwise, wheel and tire size would change the measurement. That's how BMW measures it on self-adjusting suspensions too, FWIW.Comment
