iX rear view mirrors
  • Eskie
    • Dec 2014
    • 162
    Does anyone know why the hell BMW decided to put rear view mirrors on the ix's with aluminum bases that corrode out? Why do the rear drive models have ones that don't corrode (are they made out of steel or plastic or something?). Also are they are direct swap?
    I took a spare ix mirror apart the other day to see if I could separate the base from the mirror housing/cover and it looks like they plastic weld the cover on to the aluminum base.
  • nrubenstein
    • 3148
    What are you talking about? Why do you think that the RWD ones are different?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Eskie
      • Dec 2014
      • 162
      I haven't seen any rwd models with the aluminum bases that corrode and rot out just ix's. Maybe I don't know what the hell I'm talking about :p
      • nrubenstein
        • 3148
        M3, coupe, sedan, iX coupe, iX sedan, I have literally all of those currently, and the mirrors are the same and have the Al bases.
        Edit: Of those, the M3 was the one with the corroded mirrors.
        • Eskie
          • Dec 2014
          • 162
          Well shit. I guess I've been thinking the ix had a different mirror for some reason. I just looked up the part numbers too and it appears that is not the case.
            • 34839
            They're all the same mirrors...
            they don't corrode if you don't expose them to salt lol. But unfortunately, aluminum actually has pretty poor corrosion properties.
            at least they're not plastic, like everything BMW makes now.
            • Eskie
              • Dec 2014
              • 162
              It makes sense now that I've only seen the iX mirrors corrode here in MI because nobody drives their RWD e30s in the winter here.
