WHAT IS THE 1990 325 IX's stock offset
  • franco90
    • 3185
    What is the Stock offset for my 1990 325 IX's ?
    what tires do I need to run for kosei k1 4x100 15x7
    the offset for those wheels is 38
    So what is the correct tires need to be?...............225/50/15 all around or what
    I've always been proud of being a Marine.
    I won't hesitate to defend the Corps
    "Supersquad"
    ‎"Prostitutes are a sub-category of Amusement Parks"-
  • cappa240
    • Jan 2008
    • 63
    The stock offset is 40. 38s will work. I don't think you'll be able to squeeze 225s under there. Since those are essentially the same as the stock wheel size, you should probably stock tire size. 205/55R15
      • 34839
      stock is 41mm
      et38 - 205/55-15 will work. I'm not certain about 225/50-15 though - there's a really small chance that they could work, but you will either end up having them rub on the front struts, or require rear fender flare trimming & rolling.
      • davey101
        • Aug 2007
        • 468
        my p/o jammed 225-55-15s on my basket weaves when i purchased it. they worked fine and i didn't have any troubles with them for the 6 months i had them on. but next week im getting new tires for it, that ARE 205-55-15s :D
