Difference between m20 block in iX and i models?
  • Bimmerman325i
    • 6854
    Hi iX gurus, I don't have an iX but my i motor is on its way out the door to car-part heaven. There's a guy locally selling a 325iX m20 complete with auto trans and transfer case for a really good deal.
    My question to you all is: can I simply swap the motors and the oilpans and have it work? I think the iX has the front axles and diff going through the oilpan but not the block... can I simply swap the two pans and put the motor in my car? Or is the iX front drivetrain? going to be too much of a hassle/impossibility? If not, how much can I expect to be able to sell/part out the motor/trans/transfer case? The parts have 140k and supposedly ran well until the owner rolled the car.
    Thanks!
    2017 Chevrolet SS, 6MT
    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
    98 M3/4/5 (stock)
  • JAX S50
    • 107
    yes and the oil pump
    • supernaughtIX
      • Apr 2007
      • 260
      good luck
      use search.
      88 325 IX DiamantSchwarz - TOURING - waiting...
      89 325 IX AlpinWeiß - Gone
      88 325 IX DiamantSchwarz - Parted
      89 325 IX RoyalBlau - Parted
      88 325 IX RoyalBlau - Gone
        • 34844
        key differences:
        -intermediate shaft rotates opposite direction (drives the oil pump in reverse)
        -pressure bypass valve is built into the oil pump on the ix, you'll have to drill and tap for the i oil pump and valve
        -oil pump is different
        -slightly different bolt pattern for the oil pan, you have to drill and tap a couple holes
        -dipstick tube is in a different location. There isn't a casting spot on the ix block to drill for, but you can probably make something work.
        I hope you kept your i motor for parts because you will need stuff off it for sure. it can be done but it's definitely more than simply swapping pans and dropping it in.
        • supernaughtIX
          • Apr 2007
          • 260
          whats so wrong with the i block that you can't clean it and swap the internals from the IX?
          • Bimmerman325i
            • 6854
            Originally posted by nando
            key differences:
            Wow I definitely did not know it was that different. I still have the i motor and it does work well enough to keep for a while. I think I will just keep looking for an i m20 instead of the iX drivetrain, it sounds like it will be more hassle than it is worth. Thanks for the info though!
            @supernaughtIX- my i motor is having bad oil loss/consumption issues, like a quart every 5-600 miles. I think the rings or valve seats are bad, I know it blows bluish smoke on occasion. I was hoping that swapping a newer m20 in would be cheaper than refreshing the current one. Guess I need to head off to a shop to get a quote. The block itself is not bad, so I could swap the internals like pistons, rings, valves, etc, though for the price of the iX stuff($425 local) I don't know how that compares to getting a shop to fix the issues with the motor.
            98 M3/4/5 (stock)
