iX clutch replacement
  • aaron325ix
    • Jun 2007
    • 1489
    Has anyone out there any good tricks and/or tips on how to make this as painless as possible? i have read the procedure on the iX registry, but was wondering if anyone has a better maybe more streamlined method. And also what else should i do while I'm in there ie. main seal, tranny etc. Thanks.
    AW
  • cappa240
    • Jan 2008
    • 63
    Definitely replace the rear main seal while you're in there. And lighten yours or buy a lightened fly wheel? I got mine from Metric Mechanic, I think it's $250 plus a $150 core charge.
    • aaron325ix
      • Jun 2007
      • 1489
      does it have a funny idle with that fly wheel?
      • aaron325ix
        • Jun 2007
        • 1489
        bump
        • 153624
          • Jan 2008
          • 82
          No.
          taking mass off of a stock flywheel will cause your engine to accelerate quicker after clutch engagement. If enough weight is removed.
          A good machine shop can do this when you get it resurfaced. make sure it is balanced after.
          88 325 S-ETA --Wahwooweewah
