Front caliper guide pin boot
  • E30andy
    • Aug 2016
    • 501
    Hey Guys,
    I’m chngining brake pads and noticed my caliper guide pin dust cover boot things are ripped and I’m having trouble finding replacements. Looks like it should be #10 on the attached realoem link but that doesn’t seem to be correct. Anyone know if these are available separate or do you have to purchase the guide pin kit?
    https://www.realoem.com/bmw/enUS/sho...diagId=34_0046
    Thanks!
    89 325ix coupe Diamondschwartz
    1994 Mazda Miata
  • D.Martijn
    • Sep 2016
    • 1022
    Yeah it's part 10. Not sure if those are even available seperatly. No need to get these from the dealer
    I would just get a replacement kit and replace the pins as well
    1990 325iX Touring - November 2018 R3V Car Of The Month
    1980 Volkswagen Golf mk1 1.1
    1974 BMW 2002 Touring
    Instagram
    • E30andy
      • Aug 2016
      • 501
      Thanks D.Martijn! I’m just cheap! Trying to save a few bucks the kit is quite a bit more than just the “boot”.
      1994 Mazda Miata
      • rwtags
        • Aug 2018
        • 208
        you could try to just use rubber cement, and a patch piece of rubber if you are that cheap, the part doesnt flex that much, and if its a small tear might work well, just make sure you use aggresive sandpaper.
        • The Dark Side of Will
          • Jun 2010
          • 2796
          RockAuto shows boot kits for <$10
          • E30andy
            • Aug 2016
            • 501
            just took a peek at RockAuto. They have the boot kit listed but it’s out of stock unfortunately.
            1994 Mazda Miata
              • Jun 2010
              • 2796
              Well now that you know the part number...
              Northern Auto Parts is your one-stop shop for all things automotive. Whether you need auto replacement parts or performance upgrades, we have what it takes to get the job done. Check out our site and browse the wide selection of engine, replacement, and racing products we have available online.
              • E30andy
                • Aug 2016
                • 501
                http://www.northernautoparts.com/part/wh-h18001
                Damn your good....
                1994 Mazda Miata
                • E30andy
                  • Aug 2016
                  • 501
                  Oh well, northern auto parts was a no go. I ordered the boots and the next day they refunded my money. No explanation but I’m assuming that they don’t have the boots in stock. Doesn’t look like theses are available separately anywhere else.
                  1994 Mazda Miata
                  • roguetoaster
                    Biggus Tippus
                    • 7789
                    The kit lists for something like $15 for pins, boots and bolts. Alternately, you can just get Centric rebuilt calipers for 40 each on FCP.
                    • E30andy
                      • Aug 2016
                      • 501
                      Just tried another option at Rockauto. They list caliper guide pin kit for just a few $, so I ordered it. I will update the thread when I get it in case anyone else cares to know.
                      1994 Mazda Miata
                        • Jun 2010
                        • 2796
                        D-Ohh... I should have replied with "Don't go thinking I'm any good before you have the part..."
                        Can't get the caliper pin boots? Time for a BBK.
                        • E30andy
                          • Aug 2016
                          • 501
                          So I received the caliper pin guide boot kit from Rockauto and the "kit" is just the 4 rubber guide pin boots. Just what I needed!
                          I ordered 4 "kits" so I have 16 boots right now (I only need 8). I would be happy to mail out the extras I have if anyone needs them. I should be able to just stick them in an envelope and mail regular postage, so no cost.
                          1994 Mazda Miata
                          • E30andy
                            • Aug 2016
                            • 501
                            Just put those little f’ing booties on. Man they suck to install. I guess if I had a pick it would have made things easier. I ended up using 2 small hemostats but not a fun job!
                            1994 Mazda Miata
                              • Jun 2010
                              • 2796
                              Git Err Dunn!
