Tried searching and no luck finding the actual part name
  • Cowboy.Jim
    • Jan 2020
    • 69
    i finally got around to taking the intake manifold off to put new injectors in the car as well as intake manifold gaskets and oil return tube o rings. My question is that there is a vacuum line with a valve that is inline with it that connects under the throttle body the vacuum line is all cracked and i would like to replace it. i can't remember if i can just change the lines or i have to change the actuator with it. any and all help is greatly appreciated!
  • roguetoaster
    Biggus Tippus
    • 7830
    Not sure if you mean the fuel pressure regulator or the charcoal canister/evaporatove emissions purge valve. Either way, the lines are stuff that you would buy in bulk as either fuel injection line or as simple vacuum line.
    • D.Martijn
      • Sep 2016
      • 1024
      I think he's talking about the charcoal canister fuel tank breather valve.
      When I replaced my cylinder head, I also replaced all vacuum lines and fuel lines, According to this diagram, part no for the fuel lines is 13311288284 (pre formed line)
      However, I think I might had to shorten it a little, can't remember exactly.
      https://www.realoem.com/bmw/enUS/sho...diagId=13_1326
      1990 325iX Touring - November 2018 R3V Car Of The Month
      1980 Volkswagen Golf mk1 1.1
      1974 BMW 2002 Touring
      Instagram
      • Cowboy.Jim
        • Jan 2020
        • 69
        Thank you guys for the help it would be the fuel tank breather valve. i just want to change everything while im in here since it's all fairly cheap
