Fuel leaks when filling tank
  • Hlfreed
    • Apr 2020
    • 10
    I was wondering if you guys could help me
    figure out this problem.
    i was filling my tank the other day and when it got to full the pump didn’t click off automatically but instead fuel started pouring out from the rear passenger wheel area. I haven’t noticed any fuel leaks at all otherwise, only the last time I was filling it. Nothing has leaked since it’s been parked either. The leak looked like it was coming from behind the group of hoses going into the top left portion of the wheel well.
    anyone know what could be going on or causing this?
    also what’s the best way to get in there to take a closer look?
  • reelizmpro
    • 9547
    If the pump didn't automatically turn off, it sounds like the overflow made it past the gasket and down along the filler pipe. I wouldn't worry about it too much. Although you want to make sure it doesn't happen again. BTW, you are missing the cover for the fuel vent hose.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • D.Martijn
      • Sep 2016
      • 1024
      My uncle had a crack in the big breaded fuel line, although it was at the tank side, after removing the rear seats and the cover under the seats it was obvious the lines were dry rotten.
      Might be worth removing the plastic covering panel and check for cracks in the lines as your look pretty old/original to be honest.
      1990 325iX Touring - November 2018 R3V Car Of The Month
      1980 Volkswagen Golf mk1 1.1
      1974 BMW 2002 Touring
      Instagram
      • Hlfreed
        • Apr 2020
        • 10
        Thanks reelizmpro. How do I make sure it doesn’t happen again? I just don’t fill it up all the way? Or if it does happen again I should replace the filler pipe or gasket? Is missing the cover a big deal? I’ll probably get one and put it on at some point.
        • reelizmpro
          • 9547
          The gas station nozzle should have automatically shut off. Perhaps something was wrong with that particular nozzle. Next time you fill up, pay attention to it.
          88 M3 - LACHSSILBER
