OEM motor mount height
  • lrfinn
    • Jun 2020
    • 8
    Long time lurker, first time post- Installing new motor mounts on my '88 iX- new OEM mounts are almost 1/4 inch taller than the ones removed. The newer mounts flare out at base unlike the old ones. All part numbers (11-81-1-132-324) are consistent from real OEM to the major on-line parts retailers. Attached are a couple pics showing the difference. Is this kind of height difference normal? old vs new? Do mounts compress over time?
    Thanks!
  • E30andy
    • Aug 2016
    • 502
    Absolutely normal. They compress over time. Should make a big difference after replaced.
    89 325ix coupe Diamondschwartz
    1994 Mazda Miata
    • lrfinn
      • Jun 2020
      • 8
      Thank you- puts my mind at ease as I had already installed the new mounts when re-installing sub-frame (replaced rack).
