fuel expansion tank mount bracket
  • 82eye
    • Jan 2009
    • 2010
    does anyone know if there is a north american source for the fuel expansion tank mount bracket pictured here ?
    Bracket expansion tank fuel- suitable for BMW E30 Facelift The dimensions of the holder correspond to the original. It must be welded to the body using the two 6mm holes. The remaining holes are water drains. The M6 ​​threads are used to attach the expansion tank and the small wheel arch cover. Only suitable for...
    it holds the inner fender liner protecting the expansion tank on facelift cars. unsure about earlier ones. the fender liner portion has rusted completely away on mine. i can't find a part number and this is the only bracket i could find online.
    it's simple enough i could probably fab one but there isn't much left of the old one to go by.
  • jrobie79
    • Mar 2006
    • 2526
    I just made one, pretty easy. cut a few strips of metal and test it out before you weld it to the car to make sure the holes align where they need to.
    1991 318i ---- 308K - retired
