Side molding
  • ishadow
    • Nov 2004
    • 22
    Side molding
    i removed the side molding from my 1985 325e and i need to replace them with something better, most of the pics on done up e30's don't seem to even have the side molding trim at all.
    Once i removed mine there is a nice big gap. any idea were i can get plastic molding that flushes nicely or how to work around it so it looks cleaner
    some of the pics from Rev limited show how the doors in the beginning had the trim but later, was all shaved off to a nice clean look without any molding????
    any suggestions..............
  • Jand3rson
    • 37587
    What is usually done is that gap is filled in with bondo or some other kind of filler by a body shop, and then painted over. As far as I know, no one makes a flush fitting side molding. If you want to do something about them for cheap, you can always paint them body color, but that looks kind of silly unless you do the bumper trim, too. If you want to have the gap for the side moldings filled in, it can be done, but it's not going to be cheap. And again, it won't look good unless the bumper trim is color coordinated also, because then you're left with a black line that goes around the front and rear of the car, but doesn't go around the sides.
    • ishadow
      • Nov 2004
      • 22
      allright so i ttok the trim off. sand the gap to the bare metal and fill it with some sort of good body filler i hope it works
      • Jordan
        • 12913
        Don't fill the whole channel in with body filler, and most certainly don't try to do it yourself. It will come out looking like shit.
        Have a bodyshop do it properly. They aren't going to want to paint over your work anyways.
        https://mtechniqueabs.com/
        • Digitalwave
          is a poseur
          • 6293
          You know you are going to have to have the whole sides of the car repainted then right?
          RISING EDGE
          • ishadow
            • Nov 2004
            • 22
            yeah the entire car is getting repainted over the next 2 months, i did a little bit to see what it looks like. and i think its gonna be sweet look...
            • kencopperwheat
              King of Kegstands
              • 14396
              Jordan,
              Weren't your sides filled with a bead from a welder?
              Originally posted by Gruelius
              • Jordan
                • 12913
                Originally posted by kencopperwheat
                Jordan,
                steel plate welded on, ground down and filler to smooth it out.
                • BMW BMXER
                  • 2325
                  Jordan,
                  This is the only way to properly do it.
                  Filler will crack. Trust me I hang out on minitruck boards a lot and people cheap out and use bondo and it fucks up.
                  Or trust Jordan, but I think if you do it right a shop will paint over it.
                  Sold it.
                  • ishadow
                    • Nov 2004
                    • 22
                    i can see how bondo can mess up, what about fiber glass and then aditional body filler for smother surface should be not problem if you sand it down to bare metal so it shines
                    also any oen know a site where i can get universa plastic side molding this woud be an alternate solution, anything to get rid of the original 1985 chrom molding that sticks out
                    • 808BMW
                      • 2910
                      Put black ones in instead of chrome maybe?
                      • jblack
                        • Aug 2004
                        • 98
                        Dude - side moldings, not window moldings..... I would like to see chrome side moldings - on second thought, no I woudn't....
                        • 87 325iS
                          • Jun 2004
                          • 277
                          Early side moldings had chrome strips in them.
                          Amber Fire Pearlcoat 2000 Dodge Dakota R/T
                          Schwarz 1991 BMW 535i [Daily Driver]
                          Dark Currant Pearl 1996 Acura Integra GS-R [For Sale]
                          Orientblau Metallic 1994 BMW 740i [Sold]
                          Alpinweiss 1987 BMW 325iS [Junked]
                          • ishadow
                            • Nov 2004
                            • 22
                            exactly any idea where i can get plastc ones?
                            • 87 325iS
                              • Jun 2004
                              • 277
                              Buy a can of SEM.
