The next set of measurements are for "taper". Three measurements are taken across
the journal at the same angle and your comparing the centre measurement to the ones
either side of it. If the journal is "straight" then the centre will be the same as both the outside
measurments (D = C and E on the left in the diagram below).
However if the outside measurements are less than the middle one, like on the right of the diagram below,
then wear has caused the journal to become tapered. Again there's a tolerance for how far things can
go before they require machine works, and again I'm using a tolerance of 0.0004".
Thankfully this crank measured up ok, and all reading from both the 5 main journals
and the 4 conrod journals were within tolerances, so there was no needed to have
any of the journals reground.
The other thing which we could now tell by looking at all the measurements just taken
was that this crank had never been reground before. How can we tell this? Well by looking
up the tolerance manual we could see the various sizes for each step
original main bearing size from factory = 2.1649" to 2.1644"
1st undersize (reground by 0.010") = 2.1551" to 2.1544"
2nd undersize (reground by 0.020") = 2.1453" to 2.1445"
3rd undersize (reground by 0.030") = 2.1354" to 2.1347"
As all my main journals came in around 2.1649" we could surmise that they were still
original an had never been ground down to have wear repaired. And it was the same case
with the conrod journals........
original conrod journal sizes from the factory = 1.8894" to 1.8888"
1st undersize (reground by 0.010") = 1.8796" to 1.8789"
2nd undersize (reground by 0.020") = 1.8697" to 1.8691"
3rd undersize (reground by 0.030") = 1.8599" to 1.8592"
All my conrod journals came in around 1.8894" so again using the figures above
we could tell they hadn't been touched.
So, why the hell do I need to know all this crap? Well, in a little while we're
going to get into choosing bearings for each of these journals, and, just like the
the journals can be ground to 3 smaller sizes to repair wear, the bearings can be purchased
in three undersizes aswell as standard to match the size of the journals.
Your going to need to know the size of the journals so you can buy the right bearings.
As you've seen above none of the journals on this crank required grinding down to correct them,
however, she did still pay a visit to the machine shop and that was to have each journal
micro-polished to get the journals as absolutely smooth as they can be gotten.
Not an essential step but it helps keep the O.C.D. at bay.
The only other thing worth mentioning before moving on, is if your crank should happen
to be outside any of the wear tolerances or is showing signs of pitting or scratching etc.
then your machine shop should be aware of these undersizes and will choose what size to grind
it to, to return it to a smooth surface and still ensure that you can buy bearings that will fit
the new size. But, one word of warning, upon return of your crank from the machine shop
YOU'VE got to measure it to verify the sizes. The more you rely on other people to take
important measurements the greater the risk of a fuck up, which YOU will most likely
end up footing the bill for.
Next item to address on the crank was the surface that the rear oil seal runs on.
Strange as it may sound, after 170 odd thousand miles the lip of the oil seal has actually worn
a deep ridge into the hardened metal of the crankshaft.........
A worn ridge like this is actually fairly common on a high mileage crank and
while we can't repair it, it doesn't pose to big a problem, we'll simply ensure on
reassembly that the rear crank oil seal is refitted a few mm either side of this ridge
so it can seal against a fresh non worn piece of the surface. With that in mind, the rest of the
surface could do with a little clean up.
A few strips of wet and dry sand paper starting off at 600 grit and working up
to 1000grit with the aid of some light oil soon polishes up the rest of the surface.....
