Custom Door Panels
  • cheades
    • 632
    Custom Door Panels
    Well I am part way on my first attempt at recovering my own door panels and doing custom handles. One thing not shown on the pic is there will be a flat piece welded on each end of the handles for the screws into the door. Anyways just looking for thoughts and comments on them, a door pocket will be added later with like flexible netting or something like that. My interior is now black (except for door panels) with grey/smoke seats.
  • natorious
    • 672
    it looks like you screwed a dresser pull to you door... got ant pics of the panel without any covering on it... i am gonna be doing so fabrication on the doors for my audio system sometime soon
    • Digitalwave
      is a poseur
      • 6299
      Vinyl looks ok, the door pull looks like a joke though. No arm rest? That sucks.
      RISING EDGE
      • Rob
        • 8166
        that door pull kind of sucks. if you're going for lightweight race style, use a nylon strap.
        Maybe you're going for the 50s scifi theme?
        BEERTECH
        • cheades
          • 632
          I don't really like our armrests anyways, just as easy to put my arm on my leg while driving.
          For the door pulls, would it look better to have a vinyl strap that kinda bowed out instead of the stainless door pulls?
          • trent
            damn you scrape your knuckles on the ground when walking too?
            • mph
              • Jan 2004
              • 536
              LOL.
              Current BMW's:
              2004 330Ci
              1986 European 325i cabrio
              1986 735i
              Previous BMW's:
              1989 325is RIP
              1989 325iX RIP
              2001 740iL RIP
              • M42Technik
                • 9781
                Shorten the door pull so it doesn't stick out as much. My only suggestion. Good work though on the leather covering and removing the armrest.
                Reminiscing...
                • cheades
                  • 632
                  No, but that extra leverage would have helped me get over the 90mph hump pitching in college. I actually like to sit close to the wheel and with the recaro's and lower seating position I am even a bit closer.
                  Thanks m42Tecknik, I actually f***ed up on one as it got too stuck and I slightly shorted myself on one side.
                  • Bill 84 318i
                    • 1600
                    Is that door handle gonna be screwed into the door? If it's just connected to the particle-board type stuff that the door card is made out of, I can't imagine you can close the door without ripping the thing to pieces.
                    Your seats are nuts man...keep the door cards nice and cool looking too.
                    • sovann
                      • Jan 2004
                      • 292
                      Instead of those metal handles, ever thought about using some of those grab handles that go above the door? Would look a lot neater imho and there would be no sharp bits of metal for you to impale yourself on.
                      • cheades
                        • 632
                        Bill - The handle would have a small flat piece welded to it that would use the original bolts so it would be held on just like the original.
                        My only issues with grab handles is I would like something that sticks out a bit and also what would I make them out of as the vinyl isn't strong enough to do that. How about if I bent the tubing so it arced out a bit instead of doing the 90 deg corners?
                        • sovann
                          • Jan 2004
                          • 292
                          Here you go, this is what I meant by using the grab handles:
                          http://e30m3performance.com/installs...rest/index.htm
                          took me a while to find, but i knew I had seen it somewhere before :)
                          • Dirtsquirt
                            • Nov 2004
                            • 686
                            The whole thing ends up looking almost factory.
                            • cheades
                              • 632
                              Thanks sovann, I will have to look into that. I remember seeing that now and couldn't remember where it was or what they used.
