e30 Front Fender differences?
  • T.Dot E30
    • Mar 2004
    • 536
    I just wanted to make sure, before I went ahead and bought something.
    Is there any differences in the front fenders from say a early model 325e to a late model 325i?
    Im assuming theres not, but I wanted to make sure.
    Obviously m3 ones are different. Im concerned about 318i, 325, 325i and the different years.
    Thanks
    • 34827
    AFAIK the ones that are different are cabrio and M3 fenders, all others are the same.
      • 37826
      Correct sir
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • T.Dot E30
        • Mar 2004
        • 536
        Thanks guys.
        • Streetspec_iS
          • 1622
          'cept euro ones which have the opening for the side indicator.
          sigpicM42 Brigade ... Throwing craze in the 318
          • Bryson
            • 1490
            there's a definite difference between early and late model fenders
            not sure on the year cutoff, but I am 100% positive that there was indeed a difference
            • brodee
              • Jan 2004
              • 2914
              According to the ETK you're wrong, there is no difference in the part number between the fender on an '84 325e and an '89 325is. Both are 41351979483 for the left and 41351979484 for the right.
              "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
              1988 M3 - Track Rat
              1989 325iC M50 Vert
              1989 325i Coupe
              1991 318is
              1995 318ti Club Sport
              2006 330i e90
              2008 Tundra Crewmax
              • Bryson
                • 1490
                that's what I found as well, but when I fitted an 84 fender onto my 89 is (yes it was that combo) it did not fit. I checked the ETK many times before and after. I had to modify the early fender to fit the late car, evn then it wasn't a perfect match
                • brodee
                  • Jan 2004
                  • 2914
                  Where did it not fit at? I'm curious too because my car needs a fender and I had checked on all this before and thought I'd be safe based on the part numbers. It makes sense they would be the same since you can retrofit a plastic bumper onto any year car just with changing the valance.
                  1988 M3 - Track Rat
                  1989 325iC M50 Vert
                  1989 325i Coupe
                  1991 318is
                  2006 330i e90
                  2008 Tundra Crewmax
                  • Bryson
                    • 1490
                    it didn't fit to the body of the car, I had to do lots of metal-getting-rid-of
                    since that is a word and all. and it makes sense
                    • Cinnabar325is
                      • 1064
                      I just made the mistake of buying '87 vert fenders for my '89 is. The one difference I found at close inspection (enough to make me not use them) is that at the bottom behind the front wheel, the verts had trim that was clipped on (with two holes drilled through the fender for the clips) that my '89 does not have. Plus, where the trim sits on the vert, the fender is indented. On the '89, the fender actually bumps outward in that location.
                      I'm assuming the fender would otherwise bolt onto the car?
                      '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
                      • White325is
                        • Oct 2006
                        • 5947
                        ^^ You sir are correct.
                        My fenders was fucked on my vert. All of us vert owners know what its like to find good fenders. So I just got coupe fenders and hacked the bottoms off and welded on my vert bottoms.
                        • Cinnabar325is
                          • 1064
                          Man, just my luck. The main reason I bought these fenders is cause they have a nice, fresh Zinno paint job. I'd hate to cut them up to make them match my '89 coupe.
                          So... if anyone wants a nice set of Zinno vert fenders, let me know. And apparently I'm still looking for a nice set of Zinno coupe fenders.
                          • White325is
                            • Oct 2006
                            • 5947
                            Would have saved me alot of work if I got your fenders from the get go. haha..
