"is lip" paint recommendations
  • golfdmb18
    • Dec 2005
    • 886
    Just picked up an "is lip" and I was just curious on what kind of paint you guys used for those that went black?
    I'm assuming something flexible and a little bit heavier.
    Did most of you put on 2-3 coats after a light sanding of the primer?
    Thanks
  • txleadfoot
    • Apr 2006
    • 208
    I sprayed mine with Truck Bed Liner (for texture) and then Satin Black Trim Spray.
    • Cruzer
      • Mar 2007
      • 64
      SEM Trim Black. 2-3 coats. Proven solution.
      • ak-
        • 12422
        I used some Krylon Satin black or something.
        Came out pretty super.
        1991 325iS turbo
        • Jand3rson
          • 37587
          Black Plasti-Dip. Comes out perfect trim black color, and does not chip. It's rubber and rocks will bounce right off. If/when it does get fucked up, you peel it off and repaint it.
          • ck_taft325is
            • Sep 2007
            • 6880
            I use Dupli-Color "Bumper Coating" for almost all my trim. The application and durability are unreal while SEM trim paint or even Dupli-Color trim paint are a bit easy to scuff/scratch and quick to fade.
            Black Plasti-Dip is the shit but I've had issues with the nozzle action myself. It's about 2 in 3 are faulty or don't spray well in the slightest.
            Need a part? PM me.
            • AtlBMW
              • Aug 2009
              • 10
              How about Dupli-Color "Bumper Coating" for the valence and rocker panels? Valence looks like they had a scouring pad taken to them.
              • aTron12
                • Nov 2009
                • 98
                How are the is lip spoilers painted out of the factory? I hear that they are semi gloss or OEM paint like the rest of the car.
                • Eurospec
                  • 2612
                  Body colour if I'm not mistaken.
                  • ak-
                    • 12422
                    Alright. Use plasti-dip the way Janderson recommended.
                    Mine is chipping from rocks about 3 months in..
                    1991 325iS turbo
                    • 87-325ic
                      • Apr 2006
                      • 1198
                      my SEM trim black is getting knocked off by little bits of rock.
                      its speckled now.
                      • 619E30
                        • 1753
                        I think you could do like 2-3 coats of dupli-color trim paint. haha
                        Originally posted by audiquattrot
                        bimmers b4 b*tches....remember that.
                        1990 Alpinweiss 325i - secret 500whp build
                        2000 Audi S4 B5 Laser Red
                        1990 Nissan 240sx - Drift Missile
                        2006 CBR600RR
                        • AtlBMW
                          • Aug 2009
                          • 10
                          I'm preparing to spray SEM on my rockers and valence. I wounder if it comes down to prep?
                          Not worried about the rockers but the PO seems to have taken something abrasive to the valence.
                          Paint shop said no need to primer but do I need to sand or just clean etc.
                          • golfdmb18
                            • Dec 2005
                            • 886
                            As an update I did use plasti-dip and it worked great. No rock chips or anything so far
                            • m_dudey
                              • 267
                              when using the plasti-dip, does the lip have to be prepped by sanding or anything?
