Is there a DIY on removing the chrome trim around the windows & also...
  • audiquattrot
    • May 2008
    • 3836
    the side door mouldings?
    I'm going to be prepping the car for paint soon, and wanted to know if I can salvage this stuff and/or remove it properly.
    Thanks!
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • bimmer206
    • 237
    There's a guide search and find it, the top trim pops off along the windshield then rotates off along the roof, the rest is held on by clips that I've read you'll have to break to get them off but I've heard conflicting informationn on this.
    • george graves
      • 20003
      http://www.r3vlimited.com then go to tech section. It's right under your nose.
      I removed all my trim - but I almost wish I has painted it on the car. It really seems easier. It's so easy to mess up the trim when removing it (I didn't) but if you should there is no fixing it - and it's a PITA to ship. The few people that will sell you some know this - and you'll pay extra.
      Originally posted by Matt-B
      • audiquattrot
        • May 2008
        • 3836
        thanks for the links. I'm most concerned about the drivers/passengers key holes. Are these a bitch to remove?
        #snwmble
        Current:
        Past:
        • Jean
          • 18228
          Key holes? easy.
          Order all new clips for the trim though. If you have pop out glass, just remove the glass with the trim on it (easier).
          • audiquattrot
            • May 2008
            • 3836
            Originally posted by Jean
            Key holes? easy.
            I'm assuming i can access the back of the keyhole with the interior door card removed? i don't plan on removing the glass, just the chrome trim
            #snwmble
            Current:
            Past:
            • Jean
              • 18228
              Yes, remove the door trim and you'll see a U shaped clip holding the cylinder to the door.
              The chrome trim around the rear side windows is easy to remove but not easy to install, requires removal of the glass as it gets installed in the window seal groove. Thats why I said if you have pop out glass just remove the glass. Keep in mind the trim around the rear side glass should all be removed together, the upper curved piece, the bottom flat piece and the vertical b-pillar piece.The rest of the trim is easy, but the clips aren't reusable.
              I just removed ALL chrome trim on my car and installed 318is trim.
              • audiquattrot
                • May 2008
                • 3836
                cool man thanks. yeah this car doesn't have pop out glass, but I'll follow your advice. thanks.
                #snwmble
                Current:
                Past:
                • TrentW
                  • 2815
                  I'm de-trimming my car prior to dropping it off for body & paint work and decided I'm going to shadowline the trim by having it powdercoated black. I used the tech info Jordan wrote and have everything off and the rear windows out. How do you remove the bottom trim piece on the rear pop-out windows? Seems to be riveted on and not easily removable.
                  • TrentW
                    • 2815
                    Actually, all you need to do is pop off the circular black plastic trim piece around the lock. Easy peasy.
