how to remove Late front valance
  • xxx-Lost-Soul-xxx
    • Apr 2008
    • 1953
    Ive searched,But maybe not good enough? How do you remove the front valance off a Late e30? The bumper and the shocks are gone,But where are these bolts that hold the valance in place? Thanks
  • herlsy
    • Sep 2009
    • 339
    You'll have to get the bumper brackets off, this has to be done on the inside of the fender.
    There will be 1 bolt next to the brackets joining fender to valence (each side)
    1 bolt on each side will be on the lower rad support, remove the brake air ducts to expose them.
    Remove grilles and look to the lower corner of the high beams, remove these bolts (1 each side)
    Then finally, where the fenders join the front part of the valence (lower corner of high beam) there should be a bolt on the topside (each side) then a torx bolt on the underside.
    Photo cred: Chris Tilmon
    • Dolmangar
      • Jun 2010
      • 95
      With that picture someone might think that they need to removed the engine to do it. :D
      • jpichu
        • 266
        Me :D
        http://youtu.be/aOhYdZfY9QY
        https://vimeo.com/40801938
        • McGyver
          • 4606
          couldnt hurt!
          • xxx-Lost-Soul-xxx
            • Apr 2008
            • 1953
            Thanks herlsy. Got it off, it was the ones under under the ducts, that were screwing with me.
            • herlsy
              • Sep 2009
              • 339
              Glad i could help!
