Mounting iS airdam
  • JTDay
    • Dec 2009
    • 521
    Mounting iS airdam
    Those of you utilizing the stock airdam on the 87 325is, how did you mount it aside from using the stock bracket? I've thought about just screwing it into the bumper after doing a little tuck surgery. Any thoughts on this? thanks
    Past: 1987 325iS, Bilsteins - HR Sports
    Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
    2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    I drilled holes and used nuts and bolts.......solid
    -Andy
    • siggy
      • Oct 2009
      • 329
      My 86es airdam is mounted to a tucked bumper, I drilled & tapped the aluminum. Once done, easier to mount/dismount than nuts & bolts 'cause its tough to access the nut/bolt that is inside the bumper.
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        not too bad if reach in through the tire well after removing liner
        -Andy
