bumper bolts.
  • GunMetalGrey
    • Dec 2010
    • 1499
    bumper bolts.
    so I have a 20 year old car. from Wisconsin. I need to get the bumpers off but the bolts are rusty so much so that I out a four foot pipe on a breaker bar and ended up bending the breaker bar. any ideas as to how to get them out. or get the bumpers out ?
  • BoxDriver86
    • Jul 2009
    • 912
    PB Blaster. Let it sit for a while, then carefully try again. Repeat until they come loose. You can also try heating them from the bottom with a torch. You severely risk warping the bumper with this method if it's a plastic bumper car.
    • GunMetalGrey
      • Dec 2010
      • 1499
      I can't really get at the bolts except from the bottom. and that don't really help will it?
      • NigelStu
        • 827
        Patience. And lots of penetrating spray. You might need a week or 2 with a few sprays each day. Or try some 'freeze off' spray.
        You're doing better than me... I was impatient, not enough PB Blaster soak time I had 2 bolts snap off and 2 nuts round off on the rear.
        I ended up cutting the last 2 heads off from the outside once I removed the black trim piece (metal bumpers). In hind sight, I probably could have gotten my dremel out and cut the nuts off instead...
        Ben
        Thelma-Louise, the '88is Chump Car - back to M20 power!
        2014 ChumpCar Season Schedule!
        April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
        May23-25 Watkins Glen, NY: 4th, 5th, 4th
        October 4 PittRace Sprints: 2nd in C-class
        October 18-19 NCM, Bowling Green KY: 2nd, 1st!
        Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
        Find us on FB! Schaut Speed Motorsports
        • NC325iC
          • Mar 2004
          • 6565
          mix ATF and acetone 50/50 in a spray bottle
          works better than PB. But make sure that you close the nozzle to the sprayer after youre done using it, the pressure from the acetone evaporating will cause it to ooze/spray out on its own.
          • bloodshot-e30
            • 1494
            i mean if u REALLY need them out
            saw zaw...
            just keep coating them with blaster
            i never really ran into this problem B4... lol
            ^Back in the game^
            BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
            FS thread:
            http://www.r3vlimited.com/board/showthread.php?t=214105
            • GunMetalGrey
              • Dec 2010
              • 1499
              saw zaw...
              like i said, 20 year old wisonsin car... rusty.
              • AndrewBird
                The Mad Scientist
                • 11898
                Impact wrench. The hammer helps to break them loose, better then a big ol' breaker bar.
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  Lol, already bent a breaker bar a couple of inches. Impact wrench is worth a shot.
                  • MaxBell
                    • 1391
                    I'm in the same boat. My impact wrench does nothing. I have heated them to the boiling point. (practically set the atmosphere on fire)
                    I'm prolly just going to fire my las0r at them.
                    REMEMBER: Be safe and have fun is Rule Number 1.
                    The Epic Unbuild of Clint Eastwood
                    • bloodshot-e30
                      • 1494
                      try this...
                      that might help a little
                      ^Back in the game^
                      FS thread:
                      • GunMetalGrey
                        • Dec 2010
                        • 1499
                        Well thats one way to do it I guess. Maybe keep that as a last resort?
                        • Atreus
                          • 1846
                          on mine i ended up rounding the fucking bolts... ended up taking my dremel to it an sanding off the offending parts, i had a complete spare bumper set anyway with shocks and bolts....
                          worked for me.
                          1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                          1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                          1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                          1991 325iC - Calypsorot Metallic
                          1994 540i - Granitsilber
                          Originally posted by scabzzzz
                          I've had blunts cock in my mouth, but I'm not gay.
                          • bloodshot-e30
                            • 1494
                            lol i dont recomend it, it doesnt feel to great.
                            ^Back in the game^
                            FS thread:
                            • GunMetalGrey
                              • Dec 2010
                              • 1499
                              So saw this again, I never did get the front bumper off. I ended up cutting the rear one out from the inside, took off the shock mountings. Still would like to get the front one off at some point. My impact wrench is useless on them, even with the fact that it is a 215lb-ft model.
