wet sand.....help pls...
  • JRKOUPE
    • Dec 2004
    • 3159
    Im new to wet sand/compound/polish...BUT,...I just did a black helmet visor and painted it white..came out great..
    prepped the plastic......painted a few coats white...wet sanded....painted....w/sanded
    then clear a few coats.....w/sand....some more coats....w/sand.....compound/wax...fantastic..
    here is the prob:
    wet sanded a small ...5 inch x 5 inch spot on my red 90i....w/sanded down to 1500.....but now the compund and polish WONT remove the sand marks?its hazy....why is that?....Im thinking perhaps there is no clear on the car?.....I dont know if its the oe paint.....
    how can i correct this faux pas????..
    tia
  • Ceeker
    • Sep 2009
    • 2821
    what are you using to remove the haze? First off you need a cutting compound. Two, you'll need a high speed polisher. Makita or Millwakee. Third you'll get faster results with a wool bonnet then sponge. But you gotta know what you're doing or you'll burn through pretty fast. Getting rid of haze after wet sanding by hand takes FOREVER!!! if you are good you can cut and polish with the same product at the same time.
    Also keep in mind you are working with 20+ year old paint here. Not fresh stuff like your helmet perhaps. I don't believe they used clear coat in those days on the red paint they used. I think they used enamel.
    • Tha Driver
      • Feb 2011
      • 61
      Go to 2000 wet or even finer - maybe even 3000, & use a stiff sponge pad to reduce finger marks. Use a wheel (air or electric buffer) & it should come right out.
      But do be careful as mentioned above. ;)
      ~ Paul
      aka "Tha Driver"
      Custom Fiberglass Parts
      • TrentW
        • 2815
        Ceeker, you are correct--the only colors that were clearcoated were the metallics. You've been wetsanding single stage enamel paint.
        I have no further advice unfortunately.
        • JRKOUPE
          • Dec 2004
          • 3159
          wet
          I was thinking there was no clear coat........
          paul...Ill get 2 and 3k....I hope you are right.
          I only went to 1500.....and only used Turtle wax rubbing compound then some blitz wax...very mild.
          thnx
          jrk
          • N2MYE30
            • Oct 2007
            • 5536
            I had some experience with wet sanding on my coupe. A power wheel made it much easier and had better results. Check my coupe project in my sig for more info. You got any pix?
            COTM
            • audiquattrot
              • May 2008
              • 3836
              1500 is still too abrasive. w/ 2000 or 2500grit, you shouldn't see any marks once you polish it out.
              www.instagram.com/snwmble
              #snwmble
              Current:
              '05 BMW M3 - Silver Grey/Imola Red
              '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
              '15 Mini Countryman - Blazing Red/Carbon Black
              Past:
              '01 Audi Allroad - Light Silver/Platinum Saber Black
              '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
              '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
              '90 BMW 325i - Schwarz/Tan sport *Sold*
              '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
              • margas
                • Jan 2007
                • 59
                If you're doing it by hand, try some scratch remover after the rubbing compound.
                • StereoInstaller1
                  GAS
                  • 22679
                  Turtle wax should never touch an E30, period.
                  Meguires at minimum.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    I had bought some turtle only for the helmet paint...it was fine.
                    Ill get more paper first...2k and 2500....then get at it....
