Faster way to sand down bondo?
    Right now I have a mouse sander and some 80 grit. You'd figure it would kill the bondo quickly but it gets gummed up really fast. I tried block sanding but the same thing happens. I get these spots of clumped up dust and crap. Should I wet sand ALL the time? IE spray surface with water and go? The few times I did that it just gummed up faster. I don't want to spend an hour just sanding down the first layer. How can I do it faster?
    If it keeps gumming up the sandpaper after sanding off the top surface of the bondo, you probably mixed it wrong (not enough hardener). I usually start with 40 grit & finish with 80 & then a little with 180 - all dry. A "bondo eater" or air file works best; I assume you mean "DA" not "mouse". :)
    Block sanding by hand is the best way to finish out anything.
    ~ Paul
    aka "Tha Driver"
    Custom Fiberglass Parts
      what sand block are you using? i was using a really coarse one from pep boys, it got the big stuff out quick and then i went over it with a mouse and then wet sand and done... post a pic of your block sander if you can..
        I get gummed up even if things are dry/bondo/fiberglass/spray paint. It's really annoying. Maybe I'll try 40 grit.
        Block? I just use a block of wood. I have some stuff from autozone but I get the best feel with a good old cut off section of a 2x4.
          oh ok, i just meant, i bought an automotive big tooth bondo block at pep boys for 6 bucks and it removes the big chunks like butter, but a wood block works if you get the best feel...
          good luck. i love bondo work
            love... bondo work...? Wanna come over and love on my bondo?
            I wish there were pep boys near me. No one has good bodywork tools locally. I have to order all of them online.
              oh dang man, i used to work on custom vintage motorycles and did a lot bondo work... that stuff if awesome...
              also very sad that you don't have a lot of auto places around you. it sucks to wait for stuff to get in the mail
                Do you have suggestions on tools to buy? I don't mind spending money and waiting for shipping if it'll actually work. Link meh!
                  Go to a hardware store and pickup a surform plane (cheese grater) and before the bondo cures and still cheese like consistency you can shape it down.
                  My M20 Frankenbuild(s)
                  4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                    Use less bondo next time?
                    My guess is you are using a palm sander with no dust holes in the paper, am I right? The sanding dust has no where to go and packs itself into the paper. Try using a better quality paper or buy one of these:
                    And clean the paper before it get really bad.
                      ah that would make much sense. Maybe I should just poke holes into my sand paper :)
                        Absolutely this^^^ and maybe like said earlier a bit more hardener. Also evercoat is much nicer to work with than bondo.
                        http://www.evercoat.com/
                          Most sanders come with a plate for this purpose.
                            Cheese grated on green bonding, block with 40 grit, jump to 80 grit, then 180ish.
                            Timing is crucial, practice on a junk panel. Catching the mud while still green is the trick.
                            Closing SOON!
                            Thanks for 10 years of fun!
                              Need one of those <_<
