Can I still roll?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Can I still roll?
    I found out my tires rub, they also pulled the inner lip down and bent the fender a bit, If I get a fender roller and heat the metal up real nice will I have any issues trying to reform the fender? I need it pulled a bit as well, but that seems like it would work. Just wondering if it would work well.
    Cliffs: Bent fenders
    Need fenders pulled and rolled
    Will it work?
  • dark325
    • Jul 2011
    • 34
    What are your wheel specs? How low are you?
    My vert has race springs and 16x9's 15et.. Rolled and pulled my fenders. All better
    • GunMetalGrey
      • Dec 2010
      • 1499
      et20 I think, 205, coilovers so I can play with height a bit, but I like it where it is. I dont need to pull much, just enough to clear. Just wondering if I f'ed up the fenders too much
      • dark325
        • Jul 2011
        • 34
        Even heating up my paint, it still cracked here and there.. But I was getting a bit aggressive with the roller. Go slow, take your time. Good luck :)
        • einstein57
          • Jun 2007
          • 10780
          If you do it right it won't crack unless its crappy paint or poor prep work. I've re shaped fender that got caught on the front tires and pulled out a half inch in the wrong direction. Just takes patience and a lot of heat. Almost to the point of boiling up the paint.
          www.gecoils.com
