How to Paint Inlet manifold
  • jules325i
    • Jul 2011
    • 353
    How do you paint The inlet manifold.
    Method please.
    329i
  • jules325i
    • Jul 2011
    • 353
    Please!
    329i
    • MaxBell
      • 1391
      The intake manifold you mean? On an M20B25? (the stock E30 motor)
      The easiest way to do it would be to remove it from the car and thoroughly clean it of all grease (paint will fall off grease or dirt).
      Then you will have to prime it with an aluminum primer. A can of this can be found at your local hardware store. Sand the primer with 1000 grit sand paper and prime it again.
      Sand it with 1500 grit, then get some enamel paint and spray it. Sand it with 2000 grit.
      A second coat (and possibly third coat), followed by sanding will make it look GREAT.
      Also: make sure it's off the car and the throttle body/intake ports are masked off. You don't want paint inside that thing.
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • jules325i
        • Jul 2011
        • 353
        Very helpful thank you.
        329i
        • MaxBell
          • 1391
          No worries. I love painting, I find it really zen and relaxing.
          Just MAKE SURE that the majority of your effort goes into the prep work. You can butcher your color coat and it will still look good if you CLEANED, sanded and primed properly.
          • philiprambo
            • 1
            Re:
            Thanks a lot for sharing such informative posts.
            Women Leather Blazers,
            Leather Bombers For Women
            • jules325i
              • Jul 2011
              • 353
              I can't wait to get started.
              329i
              • txtorquemade
                • 1758
                Got that manifold off yet? Your going to love that... mate.
                sigpic 1987 325is
                • amcink
                  • 788
                  If I want to paint it an specific (blue or red) color and not aluminum, what brand of paint do you recommend?
                  • MaxBell
                    • 1391
                    The intake is aluminum, so you'll have to get an aluminum primer. Then get on it with regular enamel, or even something made for higher temps, just to be safe.
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      yes, higher temp paints in the engine bay only.
                      2014 Alpine White 335i MSport
                      (Daily Driver)
                      Full Mperformance Aero
                      KW V2 Coilovers
                      VRSF Catless Downpipes
                      • Stoner Sam23
                        • 186
                        Paint relaxing. I lol'd
