rock guard detexturing
  • bastianshaw
    • Jan 2007
    • 2210
    whats the deal w this stuff can you just scrape sand it off anyone got pics?
  • ak-
    • 12422
    You will hate life for the time it takes to get it off, but it could be done.
    Looks nice without it on professional paint jobs.
    1991 325iS turbo
    • bastianshaw
      • Jan 2007
      • 2210
      HOW do I get it off?
      im thinking bout prepping for paint...
      • JGood
        • Jan 2004
        • 7959
        For the front valance? I just used a DA on mine, and took it down to metal. Took some time, but the end result after it's painted is so nice.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • bastianshaw
          • Jan 2007
          • 2210
          Originally posted by jgood
          for the front valance? I just used a da on mine, and took it down to metal. Took some time, but the end result after it's painted is so nice.
          da?
          • JGood
            • Jan 2004
            • 7959
            Dual action sander.
            • blocke
              • 1305
              Old thread, but I did this. I used "Aircraft Stripper" from local autoparts store. It comes in both an aerosol can and as a gel. I used 2 can of aerosol. Spray it on, let is sit and bubble, hit it with a wire wheel. Hose it off, repeat till all texture is removed.
              Just do it outside, and wear a mask. It is nasty shit
              Parts Wanted
              The Never-ending Resto Mod
              • 4drPwr
                • 370
                Wire wheel it off dry. Wear a mask if you can't stop yourself from breathing it in, and glasses if you insist on staring into the "output" side of the wheel. I took off all the texture from my rear valence this way. Once you get the hang of the method it doesn't take all that long.
                86Zinno
                • akorcovelos
                  • Dec 2006
                  • 1149
                  Aircraft stripper and a paint scraper works very well. Used a wire wheel to get the nooks and crannies.
                  2012 MCSCC/NSSCC CP class champ
                  HSAX Instructor
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    Does this make a valance more prone to rock chips?
                    • akorcovelos
                      • Dec 2006
                      • 1149
                      hasn't been a problem on mine. Main reason I took the texture off was it was chipped up and it's impossible to match that texture.
                      HSAX Instructor
                      • n0m4d
                        • 305
                        A harbor freight wire wheel on an angle grinder plus 1hr equals this:
                        +1 on the mask. I used a ventilator and the crap gets everywhere.
                        #30 Overengineer'd Racing - Wilton, NH
                        We need friends
                        • Eurospec
                          • 2613
                          Don't forget a set of good cleaning gloves (nitrile, vinyl, thick kind) if you decide to go this route.
                          • TimKninja
                            • 2131
                            Wire wheel + corded drill. Wont cost you more then $20 from harbor frieght.
                            1985 325e M50TU(Sold)
                            1991 318is Slicktop (Sold)
                            1990 325is Brilliantrot S50/5 Lug Swapped.
                            1992 525i Manual shitbox Winter Beater
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              Heat gun and a putty knife works well on flat surfaces, then a wire wheel or a silicon carbide disk on a grinder for the corners. Wear safety glasses, dust mask, gloves and ear plugs though. The wire wheel rings the valence like a bell. lol
                              And Aircraft Stripper sucks ass compared to this stuff:
                              Comes in a spray can too. Works 10 times quicker/better then Aircraft Stripper.
                              Oh, and expect this to happen with the wire wheel.
                              Yes, that is a piece of wire stuck 1/4" into my face.
