Adjust door frame
  • idickers
    • Sep 2011
    • 92
    Adjust door frame
    Has anyone adjusted the doorframes on their car? I just picked up a '91 318is, and the upper rear corner of the driver's door does not sit flush, and there is a lot of wind noise.
    I'm wondering if there is some adjustment to the door frame possible. I'd prefer to try and fix the existing door before finding one in a scrap yard.
    Thanks,
    Ian
  • idickers
    • Sep 2011
    • 92
    Okay, I'll answer my own question, in case it can help someone else. I took a piece of 2x4 and wedged it between the door latch and the body. This kept the door a couple of inches clear of the body. Then, with the window lowered, I pushed on the upper rear corner of the door. A couple rounds of pushing and testing the fit resulted in a door frame that is once agin flush with the B-pillar, and water-tight.
    • noE30
      • Jun 2008
      • 2260
      Did you just loosen/tighten the four bolts holding the door to the hinge? did you have to move the latch part that mounts to the body?
      I tried to adjust my doors a few weeks ago with out much luck, didnt seem to make much difference.
      Flickr
      @michael.colby on Instagram
      "All he needed was a wheel in his hand and four on the road"
      • kennyvb
        • 404
        Sounds like the OP just bent the door frame using the 2x4 as a fulcrum.
        '04 Toyota Sienna AWD (sold)
        '86 BMW 325 coupe (owned since 10/11)
        '05 Subaru WRX sedan (sold)
        '86 Subaru GL-10 wagon (sold)
        '98 Acura Integra GS-R hatchback (sold)
        • idickers
          • Sep 2011
          • 92
          Exactly. This was a low tech fix.
