how do i remove the from bumper off a 1990 325i
  • ckarsonkidd
    • Jul 2011
    • 446
    im stuck opn this guys i know its stop-id but im frustrated and need help on getting it off
  • flying_violin
    • Jan 2011
    • 325
    Yup, Vivek is correct. Two honkin' big torx bolts. T55 driver should do the trick, if I remember right. Then the bumper slides forward, and when you can get a hand in between the bumper and the airdam, unplug the turn signals. And if you have US trim, remove the side running lights before you start.
    Alpine II 318is
    • e30leigh
      • Mar 2012
      • 481
      i second that. however my car uses 10mm hex head bolts. might be a jap/ euro thing? its a jap import but euro spec. its weird
      • ClausE30
        • Sep 2011
        • 981
        makes it a lot easier to also have someone help you pull it on either side to remove and the same goes for installing it back on
        91 Alpinweiss2 318is OBD2 S52
        • e30leigh
          • Mar 2012
          • 481
          i find its fine coming off. but yes a 2nd person to help it go on straight helps at times.
          • slaterd
            • Jul 2011
            • 1731
            what they said, but I had troubles pulling mine out after unbolting. So I wrapped a rag around the tooth part of a hammer, fit it in the hole and gave it a good yank. Remember, just what everyone said, that bumper's been on there for 20+ years. it's not gonna want to move.
            Originally posted by Wh33lhop
            This is r3v. Check your vaginal sand at the door.
            • bernzpeed
              • 3917
              easiest way to remove the bumper instead of yanking/sliding it off after taking the big torx bolt is to remove the bolts for the brackets from the inside of the fender. It's a no. 8 bolt.
              to install, just blue tape one side to the fender while you bolt it back on.
              89 E30 S52
              Transaction Feedback.
              • ckarsonkidd
                • Jul 2011
                • 446
                thanks for the help guys i finally got it off after i used the star tool from the underside of the bumper
