wiper linkage - remove this rubber gasket
  • bmwstephen
    • 2463
    prepping car for some paint work. can anyone tell me how the hell I remove this gasket circled in red? It goes between the chassis and the wiper itself. I removed the 22mm nut and washer above but the rubber seems to be stuck
    Does this require removal of the linkage itself?
  • Todd Black 88
    • Oct 2007
    • 3449
    I see nothing in red, but if your talking about th rubber bushings around the arm mounts in the cowl, then yes you need to drop the linkage to remove them.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • bmwstephen
      • 2463
      fixed
      • Todd Black 88
        • Oct 2007
        • 3449
        Yep, drop the linkage to remove the two of them. Its a bushing style gasket. I just replaced both of mine.
        2010 F650gs twin
        • bmwstephen
          • 2463
          i've heard horror stories of removing the linkage but is dropping the linkage going to be just as bad?
          • ZM Blue Devil
            • Dec 2006
            • 13836
            yeah just pull it out, common wear item we stock them and just replace them for resprays or any work on the wipers.
            Levent
            %20levent@gutenparts.com
            Ladies:
            • bmwstephen
              • 2463
              so they can be pulled out and pressed back in without screwing with the linkage?
              • Todd Black 88
                • Oct 2007
                • 3449
                Not bad unless you need to remove it. Here, you do not. Just pull the heater cover panel off, unbolt the linkage bracket from the car chassis, unbolt the two nuts that the linkage bolts to on the cowl, and push the linkage down into the cowl. Remove the old gaskets and replace after paint.
                2010 F650gs twin
                • bmwstephen
                  • 2463
                  are you referring to the cover that houses the blower motor?
                  • Todd Black 88
                    • Oct 2007
                    • 3449
                    Yes
                    2010 F650gs twin
                    • Todd Black 88
                      • Oct 2007
                      • 3449
                      That's the access to the bracket that bolts the linkage/motor assembly to the car chassis.
                      2010 F650gs twin
                      • jeffnhiscars
                        • Jun 2011
                        • 6010
                        Correct.
                        I believe he is referring to the damper rings (#14) and you do not need to do anything with the linkage to remove them. If they dont just crumble and fall apart, there is a dowel (ring #13) under the washer that separates the damper from the wiper shaft. The ring prevents the damper from deforming so just slide it up and off so you can compress the damper off the cowl. It has a groove around it so on reinstall put a bit of dielectric grease in the groove, put the damper on the cowl THEN put the dowel ring back. It takes 5 min per side.
                        http://www.realoem.com/bmw/showparts...85&hg=61&fg=45
                        I replace them on all my cars (just ordered a pair today at the dealer) since they always seem to be original and falling apart. This allows the spindles to wobble putting excess strain in the wiper motor resulting in its early demise.
                        Alice the Time Capsule
                        • bmwstephen
                          • 2463
                          Originally posted by jeffnhiscars
                          I believe he is referring to the damper rings (#14) and you do not need to do anything with the linkage to remove them. If they dont just crumble and fall apart, there is a dowel (ring #13) under the washer that separates the damper from the wiper shaft. The ring prevents the damper from deforming so just slide it up and off so you can compress the damper off the cowl. It has a groove around it so on reinstall put a bit of dielectric grease in the groove THEN put the dowel ring back.
                          ding ding ding. but how do i slide the dowel off
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            Small needle nose pliers. The ring is just sitting there so not much holding it...and dont crush its little guts.
                            My other tidbit for today is that the black plastic cowl vents which are ALWAYS UGLY, are $13 per side from a friendly dealer
